I forgot the security code of nokia 1800. my mobile imei code is 352707043632979 please solve my problem
I forgot the security code of nokia 1800. my mobile imei code is 355386042857171 please solve my problem
I forget my nokia 1800 security code serial no is 358646048211575 plz sole my problem
IMEI - 357914048191408 - Nokia 1800,
[email protected]
your favour will be appreciatable
thanks in Advance
358298042533230
Please my nokia1800 is lock with security code and the. imel:356983/04/931576/2
I forget my nokia 1800 security code serial no is 359773044668878 please Solve my problem
SOURCE: nokia 2310 forget security code
There have been some reported cases where operators have changed security codes on some phones.
In these cases, the security code will be shown on the product information label on the box, usually close to the IMEI number. This number is not always marked as a security code.
If your phone was provided to you by your network operator, will not accept the code 12345, and you are certain that you have not changed it, then it is worth checking the product information label on the box before you go for the Care Point option, just in case.
SOURCE: Nokia 6100 security code error
IMEI: 353396/00/622606/7
MODEL: 6100
DEAR SIR SWICH ON SECURITY CODE
SOURCE: i changed the security code of nokia 2700 classic
Just follow the steps
Take a full backup.
First Try it:
You may try default phone and security code to remove it
Defalt phones codes is 12345 or 00000 you can use it
if the problem is same do the next,
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
If
Soft reset( factory setting)
On Symbian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you don't understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
SOURCE: i forget my nokia 5130's security code.please help
to do this you require a software get it from here www.sarunasoftware.com/
SOURCE: i forget my nokia 2600 security code.
i forgot the security code of nokia 2600. my mobile imei code is 351946035382307 please solve my problem
I forgot my NOKIA 1800 security code. Serial number is 353412047780978. Please healp me
351544/04/636101/2
351544/04/636101/2
Nokia fogat security code
I forget my security code
Imei 355371/04/396686/0
Code 0594990
how to removed nokia phone sequrity code
model: 1800
type: RM 653
Code: 0594992
Imei: 359773/04/888002/4
Made in india
