Hello
In the Closed Caption system, there can be more than one caption service provided. Each is identified by its own number. The "CC1" and "CC2" services display subtitles of TV programs superimposed over the program's picture.
In the Closed Caption system, the "Text1" or "Text2" services display text that is unrelated to the program being viewed (e.g., weather or news). These services are also superimposed over the program currently being viewed.
Press DISPLAY.
This will present the Closed Caption information •• display
Press CC while the Closed Caption setting is on the screen.
Press repeatedly until you select the desired closed •• caption service.
Closed Captions and Digital Closed Captions
Off=> On=> On during mute.
OK.
Hello
I've given you the procedure from your TVs manual itself. It also says that If complex adjustments are made and the settings cannot be restored to normal, you can reset the settings to the factory preset values.
The channel setup settings will not be changed.
The language setting will not be changed.
The PIN number setting will not be changed.
To reset it to factory settings
Enter into the "SETUP" menu screen.
In that screen you can see "Reset" option.
Hilight it by using UP or Down and [=>] or [<=] button and press enter. The set will reset to its factory settings. After that just try to close the close caption display. OK.
I've given you the descriptions from its user manual. It must be aimed to be with its orginal remote control itself. If all other functions on your TV works with the universal remote control you uses now, probabaly there is no cause to poise any other trouble. I think you have its user manual with you. Check it with. If you haven't one, contact me at the following email, before half an hour from now; because I've to go to bed, and it is quarter to 11PM here.
[email protected]
I'll send it to you by return mail. OK.
When I press the display button, I get the same window as when I pressed the cc button. In this window it says INPUT1, and underneath it says COMPONENT. These two lines are highlighted. Under these is another little box that says Video: 480i, and under that cc:- - and under that Ratings: NONE. This area is not highlighted. I tried using the down arrow key to highlight these lines, but nothing happened. Nothing changes when I press the cc button on the remote. Please advise. Thank you.
My TV is set up with a Universal remote that works the TIVO, DVD player, etc. Are you sure that resetting the TV to Factory settings will not interfere with the programming of the universal remote.
