To set alarm mode :- press Alarm 1 or 2 briefly to swtich between choices of Alarm On-Beep / DAB / FM / Off, keep pressing this alarm button until you get to the mode you want then stop pressing and leave to settle.
To set time: Press and HOLD Alarm 1 or 2 to change time. Minutes will flash first, use dial to change numbers, when you've got to the number you want press jog/select to change hour, use dial to change hour number. If you just leave it alone once you've reached the hour you want it will set where you left it, but...
If you want to specify preset channel/volume/beep tone etc keep pressing jog/preset after setting hour and use dial to set your preferences.
