Hi, you have to remove the housing underneath and check your belt. most likely is broken. the part# is 902514-01 and you can find it at sears website or service center. also before install clean the motor shaft where the belt goes by running motor and using a knife gently scraping clean of rubber from the old belt.
I had a similar problem, the belts were worn, i replaced them and it works fine.
