I have a Mitsubishi DLP WD-73737. Two days ago it worked great. Today I went to turn it on and the green power light flashes but the screen stays black like it is still turned off. Eventually the green light stays on but then a little bit later the tv just turns off. I'm not sure if it is the bulb.
Holly
Re: I have a Mitsubishi DLP WD-73737. Two days ago it...
It's not the bulb. Google Mitsubishi WD-73737 blink codes. The blinking light is a self diagnostic tool and each blink code represents a certain problem.
Check YouTube for video about error codes and adjusting screen parameters. There is a certain sequence and button combination to put you into diagnostics mode. Hope this helps you.
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Thats a very famous issue which is always caused by the DLP chip. You can get the original OEM dlp chip from the following link and comes with step by step instructions to do the replacement no special tools or soldering are required. http://tvrepairworld.com/mitsubishi_repair_kits/dlp_chip_repair_kits
mine did this on jan 1st also... called mitsu and they sent me an e mail with an update to download and install for the tv.... 2 days later mines all fixed
