Akai LCT3201TD 32 in. LCD Television Logo
Posted on Jul 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Akai tv hello my akai tv dvd combo wont turn back on . it started out not turning on until you turned it on and off a few times but now nothing seems to work. ive unpluged it several times and have left it unplugged for 3-4 min. when you push the power button the red light turns green for approx. 3 seconds. can you help me thanks benny
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
308
Points
Power button is on red but will not tv to come on
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Jul 26, 2008
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
782920
Points
6681
The power supply most likely failed on your LCD.
How old is your LCD?
1helpful
2answers
AKAI rear projection TV won't turn on
possiblity convergence needed...
main power board malfunctioning
contact akai service center
TV turns itself off after turning on. TV screen goes black.
Based on what I have read AKAI has reoccurring problems with power supply and bad DVD sound. The problem you have is caused by the DVD player trying to start. Never leave a disk in when you shut it off or you will have the same symptom you are describing.
Tv\DVD Wont turn on
Quizas el sistema de la vcr este fuera de tiempo,por causa de la banda del motor de carga el aparato tiene que ser abierto para ser reparado llevalo a un taller.
My Tv is turning off by itself
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Turn off /turn on
I have an 32 inch Akai TV/DVD Combo; the TV turns off by itself about every 20-30 min, and when I put in DVD to play, the TV cuts off.
7helpful
7answers
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Akai 20 in combo
These sets have very few parts available today and are considered throwaways. It will cost you more to repair I'm afraid then it would for a new set.
1helpful
Akai cftd15298
What you can do with the set turned off is to open the back of the set and find the DVD load and unload motor, manually turn the load and unload gear on the motor and this should eject the DVD.
LCD TV/DVD Combo image washout
Instead of reloading the DVD multiple times, when the set is doing this try jaring it with the palm of your hand on a corner near where the DVD goes in. If it clears up when you tap it, maybe you just have a bad connection inside that needs repairing.
7helpful
6answers
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
