Fl code indicates an overfill condition. If the washer is empty, then you likely have a problem with the water level pressure switch. If the washer is full of water and will not drain, you likely have a problem with the drain pump or the washer drain line. If the washer is full of water, make sure that the washer drain is clear and working properly. Check the drain hose for kinks or clogs. If you find no problems with these issues, I recommend that you manually drain the washer using a wet/dry shop vacuum. Check the drain pump and connecting hoses for problems. You may need to replace the drain pump of water will drain out of the washer properly but the pump will not work properly. A clog in the check ball assembly at the bottom of the tub can also prevent the washer from draining properly.
Hello & Welcome to FixYa
FL error indicates flood condition and is caused
due to any overfill condition that occurs inside the washer. To clear the
display you can press and hold the STOP/CANCEL button. Usually this error is
caused when overfill switch trips due to excessive water in the tub. You can
also try to clean the drain hose and check the water inlet valve. Please get
back to me if you have any other questions.
Kevin
