Creda Colonial 42352 23 in. Electric Cooktop Logo
Posted on Sep 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have a creda colonial range cooker. Yesterday I was using the fan oven and it tripped a fuse in the main fusebok of our house. I reset the fuse and now the 2 oveens wont work. The lights come on and the fan spins but the elems dont get hot. The grill elements are ok. Have I blown an internal fuse or have I blown the cooker. What should I do Kind Regards Andy
marlin siecinski
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 512 Answers
  • Posted on Oct 02, 2017
marlin siecinski
Expert
Level 2:
Prodigy:
Answers
512
Questions
Helped
160410
Points
715
All electrical appliance has a safety fuse located somewhere in the interior, most of the time it can be replaced.
always unplug electricity before attempting to repair on any electrical appliance
1 Related Answer
gerbee gomez
  • 222 Answers
  • Posted on Jan 17, 2010
SOURCE: have a Creda Solarspeed cooker and it Keep and
no..cannot fix it or repair...its normal for cooker....tnx
Maytag MER5552BAW stopped working while cooking last night.
othing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1. Home breaker flipped or the fuse blown? Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2. Power cord plugged in? Grab the plug and wiggle to determine a good connection.
3. Power cord damage? Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4. A clicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6. Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
oven relay board dacor-relay-board-92028-ap3851203_01_l-undefined-undefined-9.jpg
Oven fan will not shut off
Do a search for thermal fuse and your model. The heat can trip a fuse which will lock the fan on. Good news is it is resettable. Find the fuse and reset it.
2helpful
Ignitor stuck on burner
An ignitor is used on a GAS burner - NOT and ELECTRIC one!
Are you sure you are giving us accurate information?
10helpful
Creda stovetop ignitors won't stop clicking
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
1helpful
Creda stovetop tries to light without gas on.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
2answers
Have a Creda Solarspeed cooker and it Keep and
Fan works but there's no heat!
MAYBE YOUR ELEMENT IS BLOWN. GET A TECHNITIAN TO CHECK IT OUT.
1helpful
What cleaning product is best to clean a Creda black glassy looking cook top,along with its drip pans?
We use DeBruce Polish, also great on all of our stainless steel. You can find DeBruce Polish at debrucepolish.com
Top Creda Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Creda Cooktop Expert? Answer questions, earn points and help others
