Hi bkevryday, Hope I helped you. Thanks for using Fixya
The main reasons of your problem is the bulb which is
already came to its end. But before you replace the bulb I would advice you to work first
on itspower supply. Look for open
fuse/fusible resistor and spot some bad solder joints. This will do the same symptoms
like what it showing now. If you don't have necessary tools
and test instruments, and can't do the job yourself, I would advice you to
look for a professional to
troubleshoot the problem. Don't attempt to work in the power supply if you
don't know the safety precaution of
handling it, there some stored electricity enough to hurt you with
a little mistake only.
Have a nice day!
