Question about LG 37LG30 37 in. LCD HDTV
I HAVE A "SABRE" BRAND HD TV (AAFES BRAND) BUT
  • LG Master
  • 882 Answers
...accidentally pressed enter key to line-wrap sentence? :)
Posted on Oct 11, 2017
SOURCE:
freetek
  • 5569 Answers
SOURCE: LG 47" LCD FLAT SCREEN
IF IT WASNT DIGITAL HD I WOULD HAVE SUSPECTED HIGH VOLTAGE POWER SUPPLY BUT THAT DOES NOT EXIST HERE.
Well, not completely true; the fluorescent backlight is still a high voltage device, even if only hundreds of volts instead of kilovolts, and either the lamp(s) or the power supply for it (them) is causing the dropout of your picture. When it does it next time, look at the screen from various angles, I think you will see that video content is still there.
Posted on Sep 14, 2008
  • 92 Answers
SOURCE: LG SCREEN REPAIR
Front Screen?
Do you mean the filter glass or the actual plasma display?
If it's the filter glass, start looking for a 2nd hand one, they are almost £500 ($600), perhaps more for a 60". They are not just "glass", they have an infra red filter film on one side and a protective film on the other.
If you mean the plasma panel itself then unfortunately a replacement screen will cost you more than a new TV. You will not find a 2nd hand one.
I hope this helps.
Posted on Mar 28, 2009
farr64
  • 121 Answers
SOURCE: 'No Signal' on my LG LCD HD TV!
sounds like a weak signal or some electrical item interfering with the digital signal .check the aerial conections .farr64
Posted on Apr 30, 2009
  • 3 Answers
SOURCE: PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley,  the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
Posted on Jun 05, 2009
  • 458 Answers
SOURCE: Big white blur, cloud like, Center of LCD TV
I have seen similar effects like this & it is usually due to a flaw in the screen. A replacement screen is the only cure.
Posted on Oct 05, 2009
Remote control codes for sabre tv
When are you people going to learn. The only way you will get it to work is to find the same remote that come with the tv, That is what happens when you buy unknown brand (Electronics) Not evan a good universal remote will work on them, Stick to a known brand.Like jvc,sony, toshiba,lg,panasonic. Then you won,t have that problem. If the dog ate your remote,Because you for got to (Feed) it.
Oct 21, 2012 | Sabre LCT371BKA LCD TV
I have a 42 "
Do you have an HD ready cable/satellite box? It sounds like your tv is displaying your games in a resolution lower than what it can handle.
May 11, 2011 | LG 42LG50 42 in. LCD HDTV
Hi. I got an LED "LG LE5500"
You wil need to connect using a DVI to HDMI cable. You can get one for about 5$
http://www.amazon.com/DVI-HDMI-Cable-6ft-Male-Male/dp/B0002CZHN6
Just connect it and choose the HDMI input its plugged into(1/2/3). If there is nothing on the screen adjust the display resolution on your computer. If you are using 1080i then the resolution should 1920x1080
Apr 08, 2011 | Video Game Consoles & Games
Hello, I have purchased an LG RH397D DVD Recorder in Brisbane Australia. Eveything works well except that I cannot receive channel 73 (mate) and 90 (Go). I can press guide and the recorder will tell me...
its simple ,HD stands for "high definition" and either your TV or DVD player cant do HD ,these channels will be only screened in HD ,this is why you cant watch them ,you will need to update one or both of them .THANKS for using FixYa
Feb 10, 2011 | LG Televison & Video
My Sony Blu-ray DVD player isn't working with my LG HD TV
needs a HDMI™ (V1.3), tv set , or above. try to check the lg tv set is compatible to HDMI™ (V1.3).
Feb 19, 2010 | Sony BDP-S350 Blu-Ray Player
TCL TV
this s gizmofreak
the solution for the above problem
please refer the followin site
http://www.koders.com/kv.aspx?fid=BA11572BC5D5E4D6AAF4013F27B51C926C903899&s=aegp+aaf
please do me the rating.
Feb 02, 2009 | LG 30FS1D TV
Lg 42" hd 1080p
This could be bad capacitors on the power supply board. My LG 42LB1DR has a known problem with this and I replaced the four bac capacitors myself and saved 5-6 hundered dollars that I was also told that it would cost to fix. I fixed for under 10 dollars and about 20 minutes. LG knows about it but they dont really want to admit it. My TV was only 26 months old when this happened. The four capacitors are made by Samxon and are 2200uf @ 10v. They are junk so even if you have the entire board replaced for say $200 its just going to happen again. They need to be replaced with a different brand.
Sep 10, 2008 | LG 42LC2D 42 in. LCD HDTV
I don't know how to connect the cables from my VCR & DVD to the LG HD Plasma TV. "No Signal" appears on the screen when I try.
So, does it always say 'No Signal' or does it come up when you get it connected? If they are off when you are connecting them, that sounds okay; you'd get a signal when you turned the DVD player on (and told the TV to pay attention there.)
You might need to get an upconverting DVD or SVHS machine (since those are not normally HD) to get the TV to tolerate the signal, but the TV menus might let you activate that too. Why not look up the HD Plasma TV manual online according to the model number? If it turns out to be a monitor rather than a TV; of course, that is why it would not display those signals...you would need a separate tuner or signal selector box for that.
What's that bumpersticker abbreviation... ROFLMAORTFMYGDSOB? Good luck checking those out, since you get to decide which box renders the SD signal into HD....
Mar 11, 2008 | Televison & Video
JVC 61" Rear Projection HD61Z456. Need to take the front screen off.
IF this is in the screen... there has been issues where the entire light engine has to be replaced...
Dec 03, 2007 | JVC HD-61Z786 61" Rear Projection HDTV
LG 37LG30 37 in. LCD HDTV Logo
77 people viewed this question
RONALD CARTER JR
