Durabrand Master
- Posted on Feb 20, 2011
Re: What is the remote code for the DU1301 Model?
Hello
Four digit universal remote codes for duraband are:
0189 0135 0157
0153 0254 0458 0217
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON your TV WITH ITS FRONT PANEL POWER CONTROL SWITCH EACH TIME before trying an other code.
OK.
