D-Link Xtreme N  DIR-655 Wireless Router Logo
Posted on Feb 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reset my security key - D-Link Xtreme N DIR-655 Wireless Router
Anonymous
Level 3:
  • D-Link Master 32,281 Answers
  • Posted on Feb 20, 2011
Anonymous
D-Link Master
Level 3:
Answers
32281
Questions
Helped
7911496
Points
102259
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your computer's LAN port, open a browserand enter the D-Link's configuration URL. OR open the browser on your laptopand enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password. You can now go to the wireless settings and configure the SSID and WPA or WPA2 encryption key.
New master key tripped 2001 Yukon security system, no crank, no start, no power
Resetting the Passlock system should fix it. If it doesn't you need an auto electrician or an auto locksmith.
https://www.google.com/search?q=2001+gmc+yukon+security+system+reset
I lost my key to my 2006 Nissan Maxima. I bought a new ignition switch with a new key. I put it in and tried to start my car and it will not fire. Can I bypass the anti theft module?
Of course you can't bypass the anti theft module! It is there to stop exactly what you are trying to do!
You just need to do a Security System Reset
To reset the 2006 Nissan Maxima security put the key in the run position for 10 minutes, turn the key off, then wait five seconds, then start it.
How do i perform the 2006 Nissan Maxima security reset?
Videos as well.
https://www.google.com/search?q=2006+nissan+maxima+security+reset
I forget my security pin of Nokia 3310 (2017) IMEI NO.(35**********083). How should I off phone security
To turn phone security off:
**Press Navigation key
**Select Settings
**Select Security settings
**Select pin code request
**Turn use of PIN on or off, Select Off to turn off the function
**Key in your PIN and press the Navigation key.
**Return to home screen
Since You have forgotten your security PIN, you might want to Use Nokia 'Hard Reset ' to Reset Nokia Security Code. Though This will delete everything on your phone memory. So if you have access to phone (Phone is not locked), Please backup data. And also make sure phone battery is full before performing hard reset
Ensuring phone is turned off, press & hold below 3 keys simultaneously,
Call key + Asterisk key (*) + Number Three (3)
Ensuring that above keys are being pressed, Press & hold Power button until you'll see message "Formatting" on your screen. Release all keys & wait for formatting to be completed. Once completed, Phone is like just out of the box. Not physically though. Most importantly, your security code is now reset to default. Which means 12345
2006 Toyota Avalon, red flashing icon "key" when the key is not in the ignition. How is it reset?
That's normal. It is indicating your ignition security system is activated and your key is required to start the key or deactivate the security. There is nothing to "reset". If the red light is not flashing when the key is not in the ignition, then there is something wrong with your ignition security system.
22helpful
4answers
Help me reset my Nokia 2690, i've forgotten my security code
Nokia 2690 reset code
Code to reset the Nokia 2690
1.- Basic Reset or Soft Reset for nokia 2690 Mode
This option restores the .ini files from the ROM.
Does not erase data (photos, videos, documents) or applications from
a third party. Key Code *# 7780 # (click this combination of keys on the
keyboard in the mobile)
2.- Total Reset or Hard Reset for nokia 2690 Mode
This option restores the original operating system from the ROM.
Formats the C: partition and deletes all data including the memory
card. Key Code *#7370# (click this combination of keys on the keyboard
in the mobile)
Important: To proceed to reset, the battery must be full and the
mobile device connected to the charger. If during the course of reset,
the mobile stop receiving electricity it can ruin the internal flash
memory of the mobile device and stop function.
1helpful
How do I change the ssid and reset security
Welcome to Fixya. If you need the to change the SSID and Network Key you need to access the Wireless Settings Page.
To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security you will see the SSID you can personalize it and under the Security Mode you will see there Network Key or Security Key. The Network Key or Security Key serves as a password or security code on your network to make it secure.
You can also reset the router by pressing the Reset button at the back of it for 15-30 seconds using a Pen and a Paper Clip.
If you have questions please let me know. Thanks for using Fixya.
3helpful
4answers
How to reformat nokia 2630 through a code
---SOFT RESET (basic reset)
This option restores the .ini files from the ROM. Does not erase data (photos,videos, documents) or applications from a third party. Key Code *#7780# (clickthis combination of keys on the
--- HARD RESET (total reset/formatting)
This option restores the original operating system from the ROM. Formats the C:partition and deletes all data including the memory card. Key Code *#7370#(click this combination of keys on the keyboard in the mobile).
Rset code is 12345.
1helpful
When i want to connect with airlink 893000 it asks me security key. and where can i get the key thank you
The security key was setup by the person who first installed the router. If you do not have the key, you need to Reset the router. There is a reset button on the back of the router that needs to be held in for more than 15 seconds to reset it to factory specs which removes the security.
2helpful
3answers
Oldsmoble Alero ignition security problem
It doesn't have to be the security. a dead battery won't let the car crank either. With a security problem the car will crank but not start. The security can be reset if the battery is charged and up. Turn the key on ( do'nt crank ) the security light will stay on if it needs to be reset. If it remains on leave the key on for 15 minutes around then it will go out. turn the key off and then turn it right back on, the security light will be on again. Leave the key on till the light goes out again, then turn it off then turn it back on , wait again when it goes out turnthe key off then right back on then crank the engine and it should start. With a scanner the code will be security neweds to be reset. Thia is all anyone can do to reset the security and it's what you were charged $450 for. Following directions.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
