SOURCE: Car Audio Cutting Out
stereo is detecting a short , or low load on speaker wire and or speakers .Go behind car stereo , disconnect all speakers and apply a known good speaker to one of four wires and see if volume works normally ..If it works use same speaker on all outputs one by one ..If all are okay then you should figure out what speaker and or wires are causing issue..Also make sure your ground is okay
SOURCE: wiring harness adaptor for mitsubishi lancer.I
any auto sound shop will have these harness adapters, u can also get them at this web site, call for your application.
http://www.crutchfield.com/S-3j7E0ez3KTK/
SOURCE: Need Radio Security Code
You will most likely have to call a dealer to get that code. Don't panic yet, this is a common problem
SOURCE: Service Manual for 2005 Mitsubishi Lancer ES
It may or may not have the information you are looking for, but there is a Chiltons repair manual for all Mitsubishi and Toyota models from 2001 to 2005. It is available new for about $90 or it is generally available on Amazon used for under $20.
SOURCE: fuel pump in a mitsubishi lancer 91.
The fuel pump is located in the fuel tank and you can reach it by removing the back seat.
Rate this fixya!
Hi
The stereo in the Eclipse can be removed with nothing more than a Phillips screwdriver
Disconnect the negative battery cable from your Eclipse's battery. Remove the two Phillips screws along the bottom of the radio/climate control trim panel. Lift up the bottom of the trim panel to unlock the lower retaining clips. Work your fingers around the sides of the panel to loosen the other clips and remove the panel. Remove the four Phillips screws holding the stereo in place. Slide the stereo out of the dashboard and disconnect the wiring harness and antenna cable from the back of the device.
Also check this link if it helps:-
http://www.ehow.com/how_5938157_remove-eclipse-car-radio.html
