Whirlpool refrigerator type 2255A The problem I have is that it is freezing, even though the thermostat is at a minimum, the resistance of defrost is good (27 ohms), and the temperature switch is in series with the resistor is good (27F to 70F) is normally closed. What else might be the fault does not defrost?
Check your defrost timer manually rotate it possible stock up or replace if damage check the resistance of your defrost heater if good the freezing is normal try to adjust it to the next level of adjustment then conduct observation. check also the thermodisc it is connected to sense the ice vulging of your unit that trigger the defrost heater and defrost timer observe unit.
