There may be a senor that detects when the door isn't closed. It may be failing or mounted in a bracket coming loose. I had one that the bracket broke and sometimes it would start and other times it wouldn't. I rigged a new bracket and it works fine. You could also disable the sensor by shorting it, but you might have water leak out some day.
You will need to open the case to access the sensor.
SOURCE: how do you turn off the control lock?
Directions are under rightmost button. Please contact me if you need further help or leave feedback. Thanks for letting me help you!
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will
flush and pump out for 5 min and restart on its own..This is caused by
too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
SOURCE: What is the code to open a Whirpool washer machine
Switch on the washer. Press and hold "end of cycle" button for 3 seconds, on the right side
of panel. This is the child lock feature, do it again & it locks.
If
helped, pl rate me good!!
SOURCE: dL F code flashing on washer and will not start or
"Fdl" is a door latch error code. This is an indication of either a defective door latch, door catch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot the problem:
http://www.fixya.com/support/r4490349-fdl_error_code
I have included parts resources, and the steps required to replace any defective parts. Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
Read through the information provided and post back if you have questions. I hope you find this information helpful.
