DISH Network IR Remote Control Logo
Posted on Feb 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have an Element Tv need to program Dish Network Remote, Help
  • Official Brand Answer 184 Answers
  • Posted on Feb 20, 2011
Dish
Level 0:
Answers
184
Questions
0
Helped
225026
Points
369
Hello there this is Kimberly Escobar with DISH Network, just ran across your post and would like to help by providing you the information you need. To program the remote control to your television we have certain codes that integrate into the remote allowing it to function your T.V. Some of the codes we have for Element brand T.V are 627, 659, and 902 the procedure to integrate them is the following: Press and hold the clear T.V button located at the top of your remote until all the other buttons light up in red, once you see all the buttons lid enter one of the codes above followed by the pound key, for example 627# the T.V button should light up 3 times. After this u can try your remote to verify it works. You can find more information by following our website www.dishnetwork.com here u can find more codes for any brand of T.V and the procedures you need. IF you have any questions or concern please contact us directly we will be happy to assist.
  • 2 more comments
  • Floyd Cantu
    Floyd Cantu Feb 05, 2016
    Kimberly..... I had the same problem with a cheap element TV we purchased for our basement. Your answer was prefect and it really helped me. Just wanted to tell you Thank You!
  • Joseph Patterson
    Joseph Patterson Jul 06, 2017
    And I have been trying depressing the code for the TV that dish gave me and the codes are wrong your post really help me to figure out how to setup my TV remote and I appreciate it
  • Anonymous Jul 26, 2017
    I've had no luck. I just purchased the new Element Amazon Fire TV edition. Tried all the codes, but nothing works, Very frustrating.
  • Jason Dawson
    Jason Dawson Sep 30, 2017
    I press the TV button and they all just flash. No matter how long I hold it.
3answers
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
2answers
My new remote that came with the tv does not allow me to change channels, but my dish remote still allows me to change channels
Your dish remote is the only one that is compatible with the dish receiver. You're going to have to program all the functions you want to use to the dish remote. They are usually set up for all the normal functions, volume, power, dvr etc.
Need code for element tv to program dish network remote
Try this link it should give you the codes and instructions.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
DISH Network Customer Service
My dish remote does not control my element tv do someone needs the codes?
castro_ed387, I am unable to provide you a code as I do not know the remote model, but the steps below will help in programming the remote to the TV, and I included a link on the bottom that has the codes on it.
Program to TV:
1. Turn the Television On
2. Press and hold the gray TV button on top of the remote until all lights turn on.
3. Let go and TV will be blinking, enter the three-digit code using the buttons on the number pad.
4. Press # and test functionality with the TV
5. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television. If it works press SAT.
Link for codes: http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Tommy Faust
DISH Network
Dish Network remote will not turn the set on or off and will not adjust the sound level. Dish tells the they do not have the code For Element TV's and I will have to use 2 remotes. Can you solve this...
Sometimes the remotes have a hard time programming to the tv. Below is the link to the steps for a power scan. Instead of needing a code to program the remote, the remote will scan through the codes on the tv until it reaches the one that works. I hope that this helps!!!!
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
Dish remote
cathyw43
I have provided instructions on how to program your DISH remote to your TV. I have also provided a link with the codes for TV manufacturers. I hope this helps.
Program remote, step 6:
Ray Calo
DISH Network
Cant program my emerson flay screen tv wiyh dish
Hi tbombertigermy name is Mike Houston of DISH Network and I was going over your post and Isee where your Emerson TV needs to be programmed to your DISH Network remote. Ihave the codes 569, 632, 505, 516 and 004. What you will want to do is holddown the clear TV button for 6 seconds and then press in the three digit codeand the # button. If these keys don't work we do have a step called Power Scanand I will send the link to help with the setup. http://www.dishnetwork.com/SupportSection/power-scan-instructions
3helpful
2answers
Need code for remote. New remote needs replacing.
Cable and Satellite content providers control the remote codes,
and we apologize for any confusion during the remote programming.
Please try the following codes 10019, 0178, 10178, 0030, 10030,
0835, 10835, or for Dish Network try 627, 659 or 505. For Fios
TV (Verizon), try the code 3264. These codes may not work on some
universal remotes. If there is another code listed for Element
Electronics in your universal remote control guide, please try that
code. Refer to the Remote Control Guide under your TV’s model
number for more information.
4helpful
Dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
79helpful
13answers
Element tv remote code flx-2210
For the Direct White remote it is 10178
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
