GE JKP30CMCC 27" Built-in Single Electric Wall Oven with Dual Element Bake & Electronic Oven Control... Logo
Anonymous Posted on Feb 19, 2011
GE Single built in Oven - 27" Model - JKP14WOP2WG
GE Single built in Oven - 27" Model - JKP14WOP2WG Oven does not heat in either bake or broil mode. Pulled both bake and broil elements, both tested with resistance within spec of your other articles. Both are still in good condition, terminals also in good condition. Measured voltage at both the bake and broil elements when their respective functions are turned on. Both only measured 55 volts. Pulled the thermostat out, but I don't know how to test it. Can you tell me if I can troubleshoot the thermostat, and or if I should just replace it. When the Bake or Broil is selected, you can hear the click, and the element wires are then given 55 volts. What do you recommend I do?
  • Anonymous Feb 24, 2011
    Yes, i do have a folt meter.
    What would you like me to do?
  • Anonymous Feb 26, 2011
    Hello, any ideas on how I can troubleshoot this?
Anonymous
Level 3:
  • Master 4,399 Answers
  • Posted on Feb 19, 2011
Anonymous
Master
Level 3:
Answers
4399
Questions
Helped
876421
Points
13003
Do you have a volt reader?
  • 3 more comments
    Hey there Matt. Just saw your post. Give me a minute to look at the oven specs.
    If equipped, check the oven door and make sure it is in the unlock position. You can also try unplugging it for 10 minutes and plugging it back up. It might work but I doubt it. I am waiting on these specs to download. Just a another minute or ywo.
    two, sorry.
    Are you there? I think you may have a bad fuse. Try replacing the fuse and see if that works. Also, when you do the plug in test, go ahead and reset your breaker. Let me know what happens. Hopefully it is the fuse. If not, might need the elements.
    Yea, 55 volts are not enough to heat the elements. So the elements are fine. The oven is a 240. It needs more then 55. So, you are not getting enough power.
Convert celcius to farenheit
180 degrees c is equal to 350 degrees f (356 to be precise)
The igniter was bad i replaced it with a new one (seemed simple enough) but when i put it on broil or bake the igniter doesn't turn red, is there something i'm not doing?
The igniter is in 'series' with the gas coil that operates the gas valve. The gas coil is probably bad. You can replace the coil not the whole valve. Go to repair clinic.com and put in the model number and they will have it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
1helpful
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
1helpful
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
