Life Fitness 9500HR Treadmill Logo
Posted on Feb 19, 2011
I need to refill the waxer on my life fitness treadmill
5 Related Answers
vpaaf
Howard
  • 115 Answers
  • Posted on May 01, 2009
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Anonymous
  • Posted on Jan 08, 2010
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
gymtech
Ronnie Pelton
  • 18 Answers
  • Posted on Feb 07, 2010
SOURCE: treadmill wont run its saying waxer empty and
Does this treadmill have a wax system ? If it does it will have side access panels on the side just above the rear leveler. The picture that shows here does not but need to be sure it does not really need wax.
If it does not have a waxer- enter maintenance settings on display console,I do not have one in front of me but I believe you hold pause button down and press clear twice. This should bring up maintenance settings.
Scroll using up down arrow untill you see replace wax bag or something to that effect. select [enter ] to save. press clear clear to restart.
Anonymous
  • 16 Answers
  • Posted on Feb 20, 2010
SOURCE: Life Fitness Treadmill "FET" error
Can you please provide model of unit.
Anonymous
  • 83 Answers
  • Posted on Mar 24, 2010
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
1helpful
2answers
Display screen says waxer disconnected how do I fix
Remove the motor cover and look for the Wax lift board , it's right by the motor controller and check all wiring going to it.
1helpful
How do i refill the wax on my life fitness 9100 treadmill?
open cover on left at rear of treadmill, disconnect pipe, fill with wax kit and then reconnect pipe, 2 screws to remove wax cover.
What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • 0helpful
    Describe your 9100 Next Generation Remanufactured Treadmill Problem display shows waxer disconected ???
    Dear Sir:
    I will help you inmediately.
    1) Display does not illuminate
    when machine is powered
    on.
    Insufficient power source.
    Plug treadmill into a dedicated amp circuit.
    2) Loose 10 pin connection at
    display console or wax/lift
    control board.
    Check all electrical connections for proper
    attachment.
    3)Damaged main harness wire
    connection.
    4)Replace wire harness.
    Faulty display console or Wax/
    Lift Board.
    Verify if 8VDC is present at P1 pin, 3-4 and
    12VDC at P1 pin 9.
    a)If yes, replace Display Console.
    b) If no, replace Wax/Lift Board. See How To...
    Replace Wax/Lift PCB.
    Use VOM digital (Voltimeter)
    Hoping that you can resolve, if you need some extra help, please reach me.
    blessing.
    E.CUADRA
    MANAGUA, NICARAGUA. C.A.
    Our machine display show the following masage MOTOR CONTROLLER COMM DRD
    two possible issues
    one, unplug treadmill remove hood and make sure the main power connector to the motor control box is in properly then turn treadmill back on this has worked for me before
    two , you have blown the overload resistor on the motor control board (mcb) to check this unplug treadmill and remove the steel motor control box from under the hood remove the motor control board from inside the box and inspect it for damage and /or electrical burn smell
    if you find damage you will need to get it repaired contact glide fitness products in santa ana california 1866 637 4600 for all information including shipping . it cost $200 plus shipping which is a deal since a new one is $1000,i have many repaired by them
    a common issue for the overload to blow is friction between the belt and deck board . if you have an auto waxer , the waxer nozzle is usually plugged . the nozzle should be cleaned once a month
    contact glide for their non clogging wax to resolve this issue
    good luck
    Wen i switch on the machine,it displays CONTROL MOTOR ERROR and doesn't move at all and this came after an ice in the circuit blew due to high voltage.is tere any way of fixing it or get another...
    usually this means your motor control board (mcb) is damaged . remove the motor control box from under the hood remove the mcb from the box and check for damage and/or electrical burn smell . there is an overload resistor that usually blows up this is due to an overload caused by the issue you described or too much friction between the belt and deck board . if damaged you will need to get it repaired contact glide fitness products in santa ana california 1866 637 4600 for all details, i have had them repair many of them , it cost $200 plus shipping which is a deal considering a new one is $1000 if you need to send it for repair , remove the wax board and small electrical componet on outside of box and put in a safe place as you will need to reinstall them on new box
    if this is caused from too much friction and you have an auto waxer the waxer nozzle is plugged clean this nozzle once a month or contact glide regarding their non clogging wax
    good luck
    1helpful
    I can't reset a fault named "wax empty" and my equipment doesn't work life fitness 9100
    hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
    2helpful
    I have a life fitness treadmill and put new wax in the blader how do i start the machine and put wax on the belt?
    you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
    9helpful
    2answers
    Treadmill wont run its saying waxer empty and notify maintainence
    Top Life Fitness Exercise & Fitness Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Mike Cairns
    Mike Cairns
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
