Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System Logo
Posted on Jul 26, 2008
Sony dav-hdx576wf home theatre system
Purchased yesterday, unable to make left and right rear speakers work. wireless amplifier does not stay on etc Any ideas
  • 3 more comments
  • Anonymous Aug 24, 2008
    I have the same problem. I was online with the sony support for 4 hours.. no luck.. they have asked me to contact the level2 support now... Wish me luck!!!
  • Anonymous Dec 13, 2008
    The problem I have wih the rear speakers is that I cannot find out how to increase the sound level and the instruction book is just about worthless.
  • Greenfields9 Dec 21, 2008
    Same problem here as well. Anyone have a solution?
  • LDMM Dec 30, 2008
    Same problem...except all speakers work perfectly when playing a dvd. It's just the tv channels that cause 3 out of 5 speakers to go silent. Grrrr.
  • Anonymous Mar 26, 2014
    owner manual
A
Anonymous
Need replacement speaker cables for dav-hdx576wf
Since noone else gave you a good answer I will. I lost some cables to mine a while ago and found this awesome jerry rig solution; Go to radio shack, and ask for '14-16 gauge star ring terminal connectors' Should come in a pack of 10 and be about 2$. On the back of the unit where these connectors fit, there should be two prongs. You will need two star-rings for each connector slot. Wire up your connectors and crimp the ends LIGHTLY with a pair of pliers. The star-ring connector connected to the negative wire should be inserted to the left prong, (left if you are facing the back of the unit), and the right prong is the positive. If you did everything correctly, you should be able to make your own wires for sony stereo systems whenever you need to. Saved my ***, hope it did the same for you. Here is a link to what they look like. http://www.shopping.com/radio-shack-non-insulated-crimp-on-star-ring-terminals-10-pack/info
2helpful
2answers
My sony dav dz270 home theatre has no sound through centre and rear speaker
You must have changed the listing mode to stereo.In that mode only the left / right & subwoofer will work. Press the surround button and change it to any other mode .
1helpful
2answers
Recently purchased Sony 52 Bravia KDL52EX1
OK so its software problem? But how did you solve it?! Thansk!!
13helpful
NO SOUND IN THE TV MODE.....
Try pressing the mute button on the remote
4answers
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
