Sounds like water valve is bad.
Chris can you help with my question? My Model No. LSE7806ACE Maytag stackable washer will not fill with water no matter which way I turn the dial.
Sounds like timer is bad in that scenario
Thank you so much !!!
My Maytag stackable washer Model No. LSE7806ACE will not get out of spin mode or fill with water no matter which way I turn the dial. Someone please help it’s driving me insane.
Ok , when you pull out the washer knob to start it the water fills . Can you stop the filling by pushing the knob in? if so the water valve is ok.
There is a sensing tube from the tub which connects to the pressure switch. This is what causes the water level pressure switch to shut off at the correct level. I would suspect this as they replaced the pressure switch and it keeps filling. If this is the case there is a small hole which will cause the pressure switch not to turn off the fill valves.
You can check this by removing the tube and submerging it in some water then blow in the tube while blocking the other end , if you see bubbles it is leaking and needs replacing.Hope this helps
