Karcher 2500 PSI Pressure Washer Logo
Posted on Jul 26, 2008
Leaking power washer hose
Is it possible to repair a leaking power washer hose. Can I cut it and insert a joint of some kind.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1109
Points
Most auto stores have high pressure connectors and or machines
to make these connections. Also there are radiant heat connectors
that may or may not fit.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jun 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
10648
Points
Usually electric pressure washers only carry oil in the pump. so thats probably where you will find the problem on yours. I'd recommend check all the pump seals, and if that doesnt solve you problem check to see how tight the bolts are on that pump.
If you are looking for a new machine and/or parts for the one you have now log in to www.roncoshop.com where you will be able to find pretty much anything you need for pressure washers and airless sprayers
Anonymous
Level 1:
  • Posted on Jun 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1109
Points
Karcher k4.91 md pressure washer leaking from cylinder head i replaced rear half but still leaking don't see any cracks and seals look fine any suggestions
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Fuel leakage under driver side from a black rubber hose connecting to what looks like a type of coupling. Just read the tank is under driver side so that helps some just don't know why it is leaking there...
If the hose is leaking, maybe a new coupling or cut the rubber hose and put a new section in.
Is this a high pressure fuel hose? Or, is it a Return Hose, or is it a fuel evaporative hose?
If it's leaking, it should be repaired as soon as possible.
Good luck on this repair.
Leak water from bottom
Please try to use a good lighting to check on the bottom to confirm the exact place of leak. It is possible that the drain hose is damaged or the drain pump is faulty and leaking. If so once you identify the spot remove and change hose , tighten hose clips or patch up the leak on the joints. I don think it will be an issue once you can look into the location and you must see it first. Hope you try. Good day
2answers
The washer fluid is leaking out on my 2000 - BMW 328i
Hi Friend: Check your Window Washer Canister 1st.If its Not Leaking You'll Need to Check ALL your Hoses From The Washer Canister to the 2 Spray Nozzles . And also to Your Washere Pump.Or its Posible your Washer Pump its Self has Developed a Leak.More Than likely its a Hose thats Old and Cracked, Just Follow ALL Hoses from The Washer with your Hand and Eyes.Have Someone Get into the Vehicle After You Fill your Washer Resevoir and Have the Turn your Washer On To See if It Reveals your Leak,Hope this Helps You, Please Let Me Know.If its your Canister or Hoses there Not Expensive To Replace. From =d_hubbs
Leaking from front of washer. Does not appear to be leaking from seal, but from behind front cover bottom center. Any help would be appreciated.
I think the hose which is connected from the tray box to the drum will be damaged kindly check it and replace it if there is no problem with that hose then check the outlet hose which connects the drum and drain out valve change the hose possibly
Washer leaking water while spinning
Check the drain hose where it leaves the machine, if the square section of it is not in the plastic housing it will cut on the cabinet, if this has happened replace the hose they are difficult to repair, Other possibilities, pump is leaking, and check that the inlet hoses are not leaking and have washers in every connection.
2helpful
Subaru impreza 1993 power steering leak
YOU CANT USE A REGULAR FUEL LINE ON POWER STEERING AS A HIGH PRESSURE HOSE.BECAUSE POWER STEERING PRESSURE IS 1000 PSI.YOU HAVE TO BUY THE POWER STEERING HIGH PRESSURE HOSE IT HAS NUMBER OF PLIES MATERIAL WEAVES TO MAKE IT STRONG.IT WAS MADE FOR POWER STEERING HIGH PRESSURE.YOU DONT HAVE A BLOCKAGE .THE HIGH PRESSURE HOSE JUST WORE OUT.REPLACE IT .IT SHOULD FIX THE PROBLEM.
1helpful
Drain hose seal leak on Kenmore washer
Remove the hose and bend it in circiles see if yo see any cracks in the hose if you do replace it or if it's long enough cut out the bad part and replace it. Alos clamps wear out ver time so try replacing the clamps too.
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
