Your
pc already affected by virus ,you will need another pc to put the pen
drive.then you will format the usb drive.Actually an autorun programe
is running in your pc you can manuallly remove the virus .follow the
instruction.
http://amiworks.co.in/talk/how-to-remove-new-folderexe-or-regsvrexr-or-autoruninf-virus/
Or you can another do it another way.
You should better to install quick hill and install for scan your HDD .
Here is the link =http://www.quickheal.co.in/downloads.aspYou can use combo fix from save mode
http://combofix.net/
Follow the step.restart the pc >press F8> select save mode use
the down arrow key .copy and paste the combo fix and dubble click on it
and wait for few minutes. If you can not entry in save mode do the
following steep bellow
If your pc run in same do next
download http://www.quickheal.co.in/downloads.asp
Scan through this quick hill
Hope this helps
