You have to put your blue tooth device to discovery mode usually you hold the power button down for 6 to 10 seconds when turning on you blue tooth device then you will have to make sure to turn your blue tooth power on in you menu then you can add or search device once they pair you will need a pairing pin code .Most blue tooth device manufacture use a factory pin pairing code they are as follows 0000,1234,9999,or 1111 i hope this helps
