SOURCE: LE code
LE error is a locked rotor you need to have your hall sensor on the stator or better yet just have the whole stator replaced which comes with the sensor on it (P.S. the stator is part of the motor and has a 5 year warranty)
SOURCE: Whirlpool front loader WF665/1 spilling water during cycle
that means that the water is leaking from the hows at the back of the detergent drawer.
This is not a difficult fix, however the washing machine must be taken apart to access the detergent hose and find the leak.
Always better to call a technician.
SOURCE: can't open door of lg wd-1018c washing machine
Hi, I don't know if this is much help to you now as it has been a while since you posted your problem. I had the exact same problem and after a lot of swearing and 2 days and no help what so ever from LG I took matters into my own hands.
I took the top off the the machine and removed the small steel plate, you will know what I am talking about after you have done the same.
I had my hubby hold the tub back as far as possible and used a screw driver to release the latch which is at the front of the machine about half way down. You will see a small silver steel knobby looking thing. After the machine was finally opened I unscrewed the screws on the inside of the door and used a flat screw driver to prise the housing apart. Be careful not to drop the glass window as when the housings start coming apart the window is no longer secure.
I found that a small piece of plastic on the handle had perished and broken not allowing the correct function. A phone call to Sunstate spare parts got the new handle to me within a few days at a cost of $20.95.
My only problem now is putting the bloody thing back together. I have been at it for 3 days with no sucess. If you manage to work out how to put yours together please let me know. I hope this has helped and hasnt come too late.
Cherie.
SOURCE: "FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
SOURCE: Greasy looking spots on clothing after washing/drying.
Without seeing the spots, this is a bit speculative, but here goes,......
I'm guessing that the spots are only found on the front side, primarily of shirts, or blouses, etc. These are from grease splatters from cooking, which many times only show up after washing and drying.
The soap releases some dirt, which is attracted to the non-removed grease spot, allowing it to show up. Re-wash the clothing, pre-spotting those areas with a citrus pre-spotter.
