Remove the lower rear panel of the washer and the top cover also.
Tilt the washer forward, and from the top fit the belt round the motor pulley first, and slowly feed it round the drum pulley, turning the drum pulley at the same time.
Watch your fingers as the belt will be very tight and difficult to get round the pulley.
but this is the best way to do it, trust me on this.
If it comes off, just start again., once you have the belt on, you can then easily align it up properly on the 2 pulleys.
Testimonial: "Good advice about tilting the machine forward, this gives you a little bit more working room which is still very tight.Thanks"
