Hi, Refrigerator or Freezer not Cooling or Getting Cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
SOURCE: refrigerator not getting cold - freezer still pretty cold - perhaps not all the way
Sounds like a defrost problem or dirty coils under the machine. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
SOURCE: REFRIGERATOR NOT COLD
I have experienced this also.
If the drain under the evaporator coils in the freezer freezes up it will cause this. Because the coils ice up. Manual defrosting with hair dryer will get working again, but if drain is stopped up it repeat.
Maybe piece of paper or food in it.
OR the defroster heater element is burnt out. Same results.
Most all top Freezer Models.
SOURCE: refrigerator not cold/ freezer is
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp.
The problem could be the electronic control if
you have one or the mechanical linkages.
SOURCE: freezer working refrigerator not getting cold
Check the back wall or floor of the freezer section for frost. Check the freezer( evaporator) fan to see if it is running. Check the condenser coils( under the unit ) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with BOTH DOORS WIDE OPEN to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
SOURCE: Freezer is too cold, refrigerator does not work
The problem is with your defrost system. If you remove the back panel of the freezer you will probably find a solid block of frost/ice. This restricts your airflow across the evap coils not allowing air to circulate to the ref side. It could be a problem with your defrost heater, termination, or defrost control. Your termination will be located at the top of the evaporator coils when you remove the back panel you can usually do a visual inspection of the component to see if it looks "popped out or swollen with ice" the heater can be tested for continuity. If the heater ohms out ok then the easiest thing to do would be replace the defrost control and termination. You will need to let the evap coils completely thaw out with a heat gun or by turning the unit off w/ the doors open for 24 hrs before plugging it back in after replacing components.
Also make sure your evaporator fan motor is running in the freezer to pull the cold air over to the fresh food side. If its not running then you probably have a bad evaporator fan motor.
Let me know if this helps _MJ_
heatman101
heatman101
