Try Snappy Driver Installer - Install and Update Drivers is Free and no Ads or Malware
https://sdi-tool.org/
Did you upgrade to win10? Then you might need to download the older win7 drivers and load them, remove the win10 trackpad driver first then reinstall the win7 ones..
You can find them here https://esupport.sony.com/US/p/swu-download.pl?mdl=VGNFZ240E&upd_id=3049&os_group_id=10 Sony eSupport VGN FZ240E Drivers Software
SOURCE: Sony vaio VGN-FS640/W Keyboard Error
Check the key isn't stuck down first, if not you may have a corupt driver, go to my computer< right click>properties>hardware tab>device manager and then in the next window, go down to keyboards, click on the'+' sign and right click on the line and select uninstall. Restart you pc and the keyboard will be re installed automatically and the driver loaded. Try again.
SOURCE: I'm finding vga driver for vaio vgn-fz240e for using with XP OS
your chip is using the intel X3100. Download it from intel. click the link below
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&ProductID=2800&DwnldID=15766&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
SOURCE: sony vaio vgn-n250e laptop microphone problem
You can download what ever Vista driver required for your VGN-N250E Sony Vaio at Sony Vaio Support.
Good Luck.
SOURCE: SONY DVD RW AW-G540A ATA DEVICE IS NOT WORKING
If the device is listed you can select it and click uninstall, then promptly reboot the computer and it will automaticly reinstall it, you should be up and running in no time if that works, if not it could be a registry error related to the upper and lower filters that could take a bit of skill to repair. please let us know if the lights come on at all or the drive spools up and makes any sound. if not you might be calling sony for a replacement
cheers
SOURCE: need driver and application software of sony vaio vgn-cs60b..
where can i find the drivers of my sony vaio vgn cs60b
