did you clean the bottom bobbin area thoroughly? Remove the cover plate and bobbin reel, look for debris. Any left over cotton will cause problems, after you clean it spray some wd-40 on all moving parts.
Thanks
Adam
please leave me some feedback
Hmmm, so I presume you are trying the takeup by slowly hand turning the rotor (does this model have such)?
Are you trying it with the foot cover plate removed so you can see what is happening?
Is the needle in the right way, they can actually go in backwards.
Can you please explain when this problem occurred, ie have you used the machine recently (successfully)? Did you buy this new etc etc.
First check your "fill bobbin" lever on top: make sure it's open all the way. (Try opening and closing it several times.) If this is even slightly in the closed position, the feed nor the needle assy will not move.
Next, make sure your foot pedal is not depressed...tap it several times up-down. If the pedal is even slightly depressed, the feed nor the needle assy will not move.
move.
won pickup the bobbin thread Google SearchOne Point Advice Place a spool of thread on a spool pin.
One Point Advice Upper threading
- Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race.
Remove any loose threads or lint in the shuttle race.One Point Advice Installing a bobbin into a bobbin case
- You could be holding the needle thread too tight.
Hold the thread lightly to keep the end from going down into the shuttle.- The needle could be thread incorrectly.
Thread the needle eye from the front to the back.- The needle could be bent or improperly inserted.
Install a new needle with the flat side of the needle facing the back.- if this does not help you go to this link.
Why won the machine pick up the bobbin thread BrotherOne Point Advice Place a spool of thread on a spool pin.
Remove any loose threads or lint in the shuttle race.One Point Advice Installing a bobbin into a bobbin caseor this link might help you out some more.
cleaned everything no dust no thread pieces at all. still will not take up thread
To everyone who answered you are all amazing to help me out. I finally called my dealer and found that after trying all of you rsuggestions the timing is off on my machine so she is going into the shop for a tune up. Honestly I cannot tell you how much I appreciate your help! Thank you!!
