Just follow the instruction carefully as what the phone is asking.
Here is the steps :
If you got error lately,just turn off you mobile for 1 hour to reset the counter,cause if you continue entering wrong codes,the seem might be rejected or it goes like "simcard rejected
* turn on your mobile (mobile should be off for 1 hour to reset the counter) * if ask for the PUK code,enter it * If ask for a "NEW" PIN code,enter your new desired PIN code * If ask to verify the code,just retype your new desired PIN code.
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider. PUK codes can be obtained through the following ways -
The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider. Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
did you try: Going to ps3 main menu
go to settings tab
in the settings tab go to: accessory settings
make sure your correct bluetooth is active
then go audio device settings (still in accessory settings)
make the output and input to the correct bluetooth device
and press ok... try that
PIN code comes with the simcard. to unblock it, you will need the puk code, which should be on the paper, comes with the sim/connection.If not, ask your service provider.
hey generally i have come across mobile phones having default codes in zeros"0000" varying frm 4-8 zeros, try it, n also check ur mobile help book, n if nothing works try asking customer support 4 ur mobile n even ur mobile website.....
Try the software Mobiola Webcam lite for Nokia 6233. It works via bluetooth. It can connect your Nokia 6233 to your PC as a webcam. Search for it Now...
