Take carbs off the bike drain any fuel that might still be in carbs,remove black top and the spring,carefully remove the rubber diaphragm,the slide and jet needle will come out,turn them upside down,remove float bowl,remove float,remove the little brass jets, the smallest one is the pilot(idle) jet,the larger one is main jet,then there is a needle jet,soak in carb clean if possible,if no clean then small bread tie to clear the holes.(carb kit),do one at a time so not to get parts mixed up.
Compressed air and carb spray
