Fuji FinePix A400 Digital Camera Logo
Posted on Feb 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lens stays in off position so photos cannot be taken. It is still possible to look at pictures on card.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Feb 18, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2197918
Points
38521
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Screen reads "memory card is
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I have a pentax ist DL digital SLR. The problem is that when you take a photo and try to review it the photo does not appear, it is just black. previously taken photos come up on the screen to review but...
Are you saying that on the same card, you are able to view other pictures you took but new pictures appear black? (or is this happening on different cards?)
1helpful
3answers
If i accidently re formated my sd card with my D50 camera is there any way to get my pictures back?
That's possible. First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
take a try this recovery program called Wondershare Photo Recovery, a picture recovery tool which can recover deleted or formatted photos, videos and music. It may help with your Nikon camera. Get this program here,
Download Windows version
Download Mac version
The free trial version allows you to scan and preview the found photos, after they are found you need to pay to perform full recovery.
How to Do? Take the memory card out of your camera and connect to the computer(with this software installed) and start the scan process.
You should take care - before the deleted items are recovered, please don't save more files to the camera(SD card) where those data located in case they are overwritten. Good luck!
5helpful
Its a Panasonic DMC-TZ3. all on a sudden, LCD is not working. Monitors remains dark when I press 'On' button and the photo taken are also dark. However old photos on the SD card I can in the screen...
Hello
If you can view the pictures previously taken with the camera on the camera LCD, but the new photos just come out black, this is most probably a blown ccd.
This is a expensive component to replace, and you will also need specialized equipment to do this yourself.
I would suggest that you take your camera to your nearest repair shop and let them test the ccd.
Hope this can be of help.
Kind regards
Andrea
Mark on photos - dirt on sensor?
It is possible and quite easy to clean the sensor yourself with a little preparation. First, Google the words...cleaning an slr sensor. You will find sites that will explain the procedure in detail with pictures. You will also find out what materials you will need to purchase. Get these and have no fear!!! You can do this.
3answers
Retrieval of Pictures taken without a memory card
If you remove memory card your camera will show the pictures held in his internal 27 megs memory, as if it was memory card. Same if you connect to computer with no memory card inside.
This is all.
Lens cover problem leads to LCD problem
If the pics show up on the memory card, it's just an LCD issue.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
