I can't answer your question directly, but i can steer you toward some contact and technical information:
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Hi
F9 is a door lock error and to solve this issue you can hold
the light switch for 15 seconds, this will reset the control. If it won't work
then hold the light switch in and set the unit to clean and after a minute
press cancel to cancel the clean cycle. If still it won't work then the door
lock assembly should be replaced. Hope this helps...please post
back for further assistance.
Daniel
