Broderbund PrintMaster Platinum Version 18 Logo
Anonymous Posted on Feb 18, 2011
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we bought what I thought was the latest version, Printmaster 2011. However, it will not recognize any of the projects created in version 18 or earlier. What can we do? Thanks
Anonymous
Level 2:
  • Expert 218 Answers
  • Posted on Feb 18, 2011
Anonymous
Expert
Level 2:
Answers
218
Questions
0
Helped
46781
Points
712
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
  • Anonymous Feb 18, 2011
    You may also Use Compatibility Wizard
    1. Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
    2. Follow the instructions in the wizard.
    If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
    click Properties, and then click the Compatibility tab.
    GOOD LUCK
Our business has been using Printmaster 15 for a few years now. We recently bought a new computer with windows 7. Printmaster 15 is obviously not compatible with Windows 7. I bought printmaster 2011...
You can try version 15 in compatibility mode:
Troubleshoot Compatibility
This can help with some (but not all) programs/drivers:
1) Uninstall the program if it's already installed. Then when you install/reinstall it instead of double clicking on the install file right click it and select "Troubleshoot Compatibility"
2) Then click "Try Recommended Settings" and in the next window click "Start the Program" to install it.
3) After it installs see if it works correctly. Please note - some programs may not be able to run in Windows 7.
More details about how to make older programs run in this version of Windows:
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
2helpful
I have used PrintMaster 10 for a number of years on my old computer-XP. I recently purchased a new computer and wish to put the program on my laptop( Windows 7). I tried choosing the compatibilty method...
The only solution with this older software that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or are willing to upgrade to one of these versions), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. You can't have a printer installed on both the main computer and the virtual one at the same time. You will be asked to uninstall the printer if you try.
Your other option is to upgrade to PrintMaster Platinum 18.1, see http://www.broderbund.com/ for details, which is compatible with Windows 7. This will import your Printmaster 10 projects.
I hope this helps.
3helpful
2answers
Can printmaster gold 18 be run on windows 7
Broderbund PrintMaster Gold Version 18 is not compatible with Win 7.
The Printmaster Platinum 18.1 is compatible.
1helpful
I am using an old (but good) Printmaster Platinum 11 and would like to update. A few years ago I got a detective Gold 18 which I cannot use. I have Windows XP Home and am being told that I must update my...
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Would like to order Printmaster 18.1, compatible with Windows 7 but as I live in Australia I am unable to order online as your orderform does not cater for sahipping to my country. I have used...
3helpful
I just bought a new computer loaded with windows 7 and I want to know what I can do to get my Printmaster 18 to work with this system. I just purchased Printmaster 2011 and it doesn't seem to be as user...
Unfortunately, the 'New' PrintMaster 2011 will not import any older PrintMaster .sig files created prior to PrintMaster 2.0. This means that over 1,100 projects I have,going back to 2004 are now useless. Did they even consider this before coming out with the new version? Is this the way that Broderbund treats long time customers of their product? Apparently so...so I will no longer be using any of their products from now on. I don't see any excuse for their actions.
1helpful
2answers
I could not install PrintMaster Publishing Suite 7.0 on our new computer running Windows 7. Is this software compatible with Windows 7? Is the a version to upgrade to that is compatible that we can work...
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
9helpful
I bought a new computer with Windows 7. Is Printmaster 18 compatible? I have started to install it but a message came up stating there were 'compatibility issues' Is this correct and if so, what can I do?
This should answer your question
I understand that you are inquiring if Printmaster 18 is compatible with Windows 7. Our developers have tested every aspect of Printmaster 18 to see if it will function properly on Windows 7. It has passed all tests except one, which is the Save As PDF feature. Our developers just became aware of this and are working on a resolution to make it work on the Windows 7 operating system. We apologize for any inconvenience this has caused, but we can assure you that we will provide a fix for this as soon as possible.
http://www.broderbund.com/store/broder/Content/pbPage.ProductSupportMain
2answers
Printmaster 17 won't open projects created in printmaster 11.
printmaster 1 was for windows 98, ver 17 is for XP. it depends where your saved projects are. if they are on CD media then that is READ ONLY and they must first be transferred to a C:\ drive and their ATTRIBUTES for each and every file/folder of the project need to have the Read Only attribute removed. you can do that via CMD.exe eg if your project was inside a folder called c:\myprojects\????? then you would type in ATTRIB/S c:\myprojects\*.* -R then your projects might be valid as they could be UPDATED/Altered by the new version but thats just a guess.
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
