Fridge will only cool to 48 degrees on max but the freezer will cool to 5 below 0. Coils on back side of unit is hot even on ac, dc or gas. Temp. in fridge seems to get colder at times but will not stay cold. This fridge is only 4 years old and would freeze things in the fridge at a setting of 5. Wasn't seemed to work properly the 2 times I have used it this year.
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
[email protected]
www.coachtech.info
734 777 6432
