Building Materials Logo
Anonymous Posted on Feb 18, 2011
I want to frame a closet do I just need 2by4's or should I use 2by6's
Anonymous
Level 2:
  • Expert 225 Answers
  • Posted on Feb 18, 2011
Anonymous
Expert
Level 2:
Answers
225
Questions
0
Helped
117873
Points
655
Framing lumber for interior non-load bearing walls is typically 2x4 in house construction. Even load bearing interior walls often only require 2x4 framing, but could require 2x6 framing depending on the load they carry(the load is how much weight of the roof or upper floors is being supported by the wall). Sometimes 2x6 framing is used for interior walls that have plumbing drain pipes to make it easier to fit them, likewise if the interior wall has heat/air ducting in it. Another reason to use 2x6 is to allow better sound proofing or higher insulation rating. If none of the special cases I've cited apply, then 2x4 is what I would use to frame a closet.
Testimonial: "it is a load bearing wall so 2x6's it is thank you"
mikenearman
Level 2:
New Friend:
  • Expert 127 Answers
  • Posted on Nov 24, 2018
mikenearman
Expert
Level 2:
New Friend:
Answers
127
Questions
0
Helped
75786
Points
189
2x4’s. Frame them 16 inches on center and lay them out so your brackets and up and in a bit ce and even fashion.
Luke Holsey
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 18, 2018
Luke Holsey
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
355
Points
Use 2 by 6's to better secure your frame go to http//www.dyi.com
Kami
Level 2:
Novelist:
  • Expert 307 Answers
  • Posted on Nov 06, 2018
Kami
Expert
Level 2:
Novelist:
Answers
307
Questions
0
Helped
155662
Points
375
The lumber is two by four. Trim would add to the width.
  • Kami Nov 18, 2018
    Addendum: Thinner, 2-inch thick walls called stub walls can be used to divide narrow closets built single file, such as wardrobe closets, wherever sound-proofing is not necessary. Stub walls may also be used to build shallow cabinetlike closets like a pantry or broom closet. However, the door jam may still require two by fours. Walk-in closets should have normal walls 4-5 in thick. Closets often have the thinnest wallboard.
Extra Wide canvas closet can't get cover over for frame
check that the instructions don't say collapse the frame , place cover over frame then expand frame
Jun 10, 2018 • Motorcycles
tip
Help - My Bedroom Doesn't Have a Closet for Hanging Clothes
Most bedrooms come with built in furniture closets for hanging clothes. But sometimes you come across apartments that don't have any facilities.
Here are some suggestions for what to do if you bedroom is lacking in a hanging space.
1. Check out some of the cheaper furniture stores. You might find that you can pick up a closet for a lot less money than you realized.
2. Buy a moveable fold-up closet. You can get ones made of canvas or plastic that can be folded up and packed away when you don't need them. They're not as stable as wooden closets but make a great temporary solution.
3. Use a shower rail or pole that you can attach to 2 sides of a wall. This can provide a secure hanging space without needing a big purchase.
on Dec 16, 2013 • Retail Supplies
Need to get directions for putting together a extra wide canvas closet
Manual for extra wide canvas closet - Fixya
www.fixya.com/support/t23647992-manual_extra_wide_canvas_closet
Feb 24, 2014 - manual for extra wide canvas closet - Real Simple 60 Wide Canvas Closet question.
How do i fix my damaged closet door
To be able to assist, I need more information. What sort of damage? Perhaps post a picture?
Sep 18, 2013 • Home
Closet door latch (recently) doesn't extend fully with use of a strikeguard
It could be either the latch has jumped off the Cam inside the latch mechanism or the spring inside has jumped off back a bit onto the same Cam, I had the same problem with mine. If it's the simple ball bearing type it may just be dirt and so a wee squirt of WD40 may do the trick.
HOW TO STOP DUST BUILDUP IN AC CLOSET
Seal closet with caulk or mastic or foam.including top, sides, platform and around base of unit. If base is not sealed it can pull from outside of closet through door. If base is sealed but top and sides of closet are not then return air can pull from inside closet from attic or inside walls. Either will turn your door casing into a filter.
1helpful
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
1helpful
Were is the serial number on a 1992 wilderness camper
Normally a silver tag up in front left corner, stuck on side . If worn off, you may be able to look real close on tongue for numbers as well, as on some models they were stamped into frame. Look inside all your cupboards, closets etc, just in case too.
Need to get to the back of the unit...
There are no locking mechanisms. There are two things to watch out for. The lower outer arms of the frame slide to the inside of the front washer panel, but are not attached other than by tension. Also, the brcket frame and the washer both have their own leveler feet. It is easily possible to raise the frame so tightly into the washer that it in effect has the washer sitting on it, making it almost imposible to slide out the washer. If necessary, lower the frame levelers to create a small gap all the way around between the lower frame arms and the washer. Note there are electrical control cables between the control panel and the washer that must be disconnected to pull it out.
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
