Not sure what type of reset you are after. Is the dishwasher not responding to any panel switches.
Is the keypad locked, i.e., is the control lock light on? Then press Energy Saver Dry button for 4-5 secs.
Are some lights flashing and dishwasher will not start? Have you tried to turn mains power off and back on?
If you think the controller needs a reset, you could try this sequence of keys within 7-8 secs.
hi temp scrub/ energy saver dry/hi tempscrub/ energy saver dry/ hi temp scrub/ energy saver dry.
If the reset sequence has worked correctly, then all lights should light up. Press Cancel to exit from reset mode. I am assuming you have a users manual. If not then download from here.
Please rate the solution if it helps your problem otherwise post a comment
Sorry,but there is no reset button on dishwahers
Hi friend, I appreciate your post!
I understand you are trying to locate a reset button on your dishwasher FDB1502RGC0. Generally dishwashers do not have a reset button on them but in order to reset your appliance as a whole. You would disconnect power to it by unplugging it or turning off the household circuit breaker for ten minutes and turning it back on. Hope this helps. -Matt
