My Kenmore dishwasher just stopped working mid-cycle. There is water sitting in the bottom and it won't turn on. Is there a reset button on this thing anywhere? It seems strange that it just quit with no warning.
SOURCE: Kenmore Model 16253 - Stops mid cycle
Sounds to me that the heater is not working, if you have just bought it, it must still be under Guarantee so go back to the supplier.
SOURCE: viking dishwasher quit working
Possible bad door switch, thermostat or timer issue, call for service, make sure the tech. knows how to fix Asko dishwashers as that is what is in on the inside. Be sure that you are getting power to the unit.
SOURCE: kenmore elite dishwasher stopped in middle of cycle
My Smeg (never buying brand again) dishwasher UKSTX1 has error message e9 not covered in manual
SOURCE: kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
I have the same problem - the built-in Kenmore dishwasher just stopped mid-cycle, prior to the opening of the soap dispenser, and won't do a thing. If I turn the knob fully around the cycle, the light never comes on and nothing happens (except that it did trigger the opening of the soap dispenser). I would love to know if there is a fix for this. (I'm not positive this is the right model, but it's 7+ years old and I can look up the model number after work.)
