SOURCE: Neff Dishwasher
Hallo Champer, 1)Be sure water supply is arriving with enough pressure. 2)If the hose between the crane and dishwasher has an aqua-stop ( or water-stop) which you recognize at the hose being enlarged twice the size close to the crane, possibly water supply can be blocked there. You can change it temporarily with a regular hose ( for garden or car-wash ...). If dishwasher is doing the job buy a new hose with Aqua-stop in a regular electro- household appliances shop. 3) If this solution is not the good one, you might check in fact to the inlet valve, which you find at the other side of the metal plate where the watersupply is flooding inside the diswasher. Generally a white coloured threaded plastic pipe. Unplug your dishwasher, close water supply (!) and disconnect the water hose. Open the dishwasher ( either top-plate and/or back-panel). Now you see the inlet-valve ; unscrew this one and mark the position of the 2 electrical wires, which you also unplug then. Also unplug the internal water drain, and ask again a regular shop (see 2) if they can check this valve and if necessary get a spare part. Oeffti, hopefully this helps else let know.
SOURCE: Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
SOURCE: How to remove bottom panel on front of Hotpoint model HDA 465-01 Dishwasher
two different models one is lean it back two screws hold the complete base on and you just twist the pump off. the other you can access the pump from below the internal filter on the left one torx screw and you can see if there is anything blocking the pump. regards
SOURCE: Leak of water in base of unit
is the plastic unit a salt chamber,depending where the hole is you may have to replace it or is it an over filling problem,its hard to know without seeing it hope this helps you.Thanks Ian.
SOURCE: water not going through spray arms
possible you have a leak and the bottom tray has water in it. tilt the machine back to 45deg and see if water runs out of the back. if it does, after putting upright, the machine will work - then find the leak!!
