DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale Logo
Posted on Feb 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My scales i turn it on and the number keep going different and there is nothin on it
  • tina hall
    tina hall Sep 29, 2017
    if you have a cell phone near your scale it will make it do that
Anonymous
Level 3:
  • Master 1,940 Answers
  • Posted on Feb 18, 2011
Anonymous
Master
Level 3:
Answers
1940
Questions
0
Helped
954274
Points
5951
  1. First, try recalibrating the scale with nothing on it.
  2. If there is a reset button on the device, press it.
  3. Try replacing the battery.
  4. If it still acts up, it's probably time to get a new scale.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2answers
How do I set the weight on the scale. Model # is ww707
I've found your manual on two different website but I'm unable to link them here. Please contact weight watchers and ask them to email you the manual for your weighing device so that you calibrate the device or factory reset it in order to weigh properly. The manual is only 2 pages.
1helpful
2answers
Dashes
I have a Health-o-meter but not the same model. Mine still has the instructions pasted (loosely) to the bottom.
The secret is that you must initially press the lower (left or right side) corer for just a second or two. That causes a few dashes and then the scale reads 00.0. Then get on the scale and get your reading.
Alternative behavior:
If you initially press the corner for more than a few seconds it will cycle through User Numbers one through four. If you use that feature it remembers your weight from the last time so you can see the difference.
How do i set the distributor that runs counter clockwise
No different than setting one that turns clockwise. You set it in so the rotor on the distributor shaft lines up with the number 1 cylinder spark plug tower on the distributor cap, and then you follow the firing order around in a counter clockwise direction.
This will get the distributor set right, as long as you have the number one cylinder at Top Dead Center of the compression stroke before you drop the distributor in.
To find TDC of compression stroke, pull the number one spark plug. Turn the engine over by hand with a socket on the crank pulley-turn it clockwise-or you can have someone bump the starter over in short bursts. With your finger over the spark plug hole, turn the crank over until you feel air pressure build up in the cylinder. Now look at the timing pointer scale next to the crank pulley. Keep turning the crank until the notch or mark on the crank pulley lines up with the zero degrees mark on the pointer scale. The air pressure behind your finger tells you that you are on the compression stroke. When the crank pulley notch lines up, you are at TDC of the compression stroke. The piston will be at the top of its travel. Now you can drop in the distributor. Keep playing with it until you have the rotor pointing directly to the number 1 spark plug tower. The shaft will turn a little as it is dropped in, so you start with the rotor a little ways back from directly to number 1.
When you get onto the scale (Taylor Lithium 7506), the numbers just keep cycling and never stop. We tried changing the battery, even though the scale is less than three months old, but it still does the...
Turn it over - take out battery and check with multimeter to ensure it is still workable - let sit for 10 to 15 seconds - replace battery - set it on level surface and step on and back off. Step on it again and it should now work.
12helpful
2answers
Scale displays OUT2
you need just to recalibrate it:
The procedure is standard for semi-all models of pocket scales, but the way how to get to calibration mode differs from model to model (or vendor to vendor).
In brief:
1.While turn-on get to the calibration mode (by pressing and holding the ON button, or holding TARE while turinig on) You should hold this "magic" combination until the LCD will show a number (large number - it was more than 2000 in my case). This number is a raw data from the sensor.
2.Now release the "magic" button.
3.Press it one more time, the display will show 2Ero and then 100.0
4.Now put calibrated weight of 100 grams on the scale and wait 3 seconds.
5.Press "magic" button again.The display will show CAL and then PASS.
6.Now remove the weight and turn off the scale.
7.Thats all - now you can use your scale as usually.
Help!! I don't know what to do, my samsung m300 cellphone keeps freezing! And now its stuck. Today it froze for 3 hrs!! Every time I flip it open, my contact list comes up but I can't scroll up or down,...
sounds like you got a bad egg i got that same phone with sprint and it works great ,.if you just got it just get the warrenty number and they will replace it for free.,,......,,,,,,
6helpful
Conair WW41 Scale
To totally reset the scale and remove any old data in the users take battery out for 2 hours.
To use the USER functions:
Tap scale to turn it on
When you see "0.0" press
Press SET button. "P-1" will appear and blink
Use UP/DOWN button to select a user number
once desired user number (1-4) appears press SET button to confirm
when 0.0 appears step on scale this will enter your starting weight
press SET to confirm
scale automatically sets a goal weight of 10% below starting. you can raise or lower it by using arrow buttons-Press SET to confirm
Tracking weight
tap, see 0, select user number. Scale displays start weight, then goal weight then 0.0 and you weigh yourself. In the smaller windows it will display last weight and the difference between current and last weight then diff between current and start then diff between current and goal
Top DigiWeigh Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a DigiWeigh Measuring Tool and Sensor Expert? Answer questions, earn points and help others
