https://www.quora.com/How-do-analog-watches-know-to-change-the...
QuoraThere is a gear within an analog watch that is used to change the date at the appropriate time. The gear ... Watches: What is a fair price for a authentic 1970's vintage "McQueen" Rolex Explorer II? Why does the day start at midnight?
probably because you have it set to 12 pm midnight and not 12 noon so at 12 noon it is actually midnight when the date will change
reset the time of the day to am or pm and any pm settings will change the date at 12 midnight.
Pull the stem out to the time set level. Turn the hand around until the date change. Now push the stem back in, pull to date set level and change to current date. Now the watch is at midnight for that current date. Note you can set to current time of day. The Watch will automatically change to correct date for next day at midnight as it should.
The date changes around midnight and you can usually advance the date by going past midnight until the date changes and then turning the watch backward to a time shortly before midnight and then winding it forward again.
How far back you need to go you will have to find by experiment but it should not be very far.
When you pull the crown out there are two positions. The first is the day/date setting position. Turn the crown one way and the date changes, the other direction the day of the week changes. Set both the day and date to yesterday. It will become evident why when you finish. Now pull the crown all the way out and notice when you turn the crown the hands move. Advance the hands to the 12 o'clock position in a clockwise direction. As you pass 12 the date may begin to change. If not then you now know that was noon and not midnight because the date only changes at midnight. If the date did not change advance the hands all the way around 12 hours. This will now be midnight and the date should begin to change. It may be almost instantaneous or may take until 12:30 or so. Continue advancing the hands to 4 o'clock. You should see between midnight and 4 the day of the week advance. Now the day/date are correct for today and the final step is to set the correct time. Remember, you are now set a 4 AM. Advance the hands to the correct time. That means if it is 3 in the afternoon, you must advance past noon to 3. You cannot go backwards. That would be 3 AM!
The date changes hen the hour hand passes midnight (more or less).
To change the date for more than one day wind it past midnight and when the date has changed, turn the time back past midnight and then forward again.
You may have to experiment to find out how far back before midnight you have to go before going forward again, but at least you don't have to wind it 24 hours for each day!
you need to reset time ,, pull crown out and set time (notice Date change) at 12 or after 12 that's actually Midnight, now count from there 1, O clock, 2 O clock , 3 o clock and go on to the desire time puch crown back to its normal position
hope this help
from
Amfix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
The Skagen watches have two-step stem; fully pulled out will change the time and partially pulled out will change the date (only goes one way so try turning it counter-clockwise or clockwise - I forget which is correct). It's easier to find the date length by extending it all the way and then go back toward the case. It won't change the date if you run it through a 24-hour cycle - you have to do the half-way thing. Hope this helps.
