Slendertone Fortex Logo
Posted on Feb 18, 2011
My slendertone belt keeps beeping with a triangle next to it. I can't turn up the intensity and it won't vibrate but I'm not sure why. What's the problem?
Natalie Vo
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 02, 2013
Natalie Vo
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
36641
Points
I just replaced new pads but that triangle still appear. Can't really do anything with the belt right now. Really frustrating.
  • 4 more comments
  • Kieran Hendry
    Kieran Hendry Nov 25, 2014
    Mines same i rang them up, and said buy a new battery
  • DM Sammons
    DM Sammons Mar 15, 2015
    To fix the problem, you don't need new batteries or new pads. Instead, put rubbing alcohol generously all over your stomach and then place the pads back on. Your Slendertone will work again like new. You're welcome.
    -DMSammons
  • DM Sammons
    -DMSammons
  • Kieran Hendry
    Kieran Hendry Nov 24, 2015
    Didn't work lol
  • Jenny Coakley
    Jenny Coakley Mar 01, 2019
    THANK YOU FOR THIS!!!
  • Jeann Heal
    Jeann Heal Feb 16, 2022
    Did you ever find out? I'm having same problem. I'm thinking change watch batteries..
Nadia Henzee
Level 1:
New Friend:
  • Posted on Feb 22, 2019
Nadia Henzee
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
36641
Points
5
Wow, thank you so much DMSammons I just tried the rubbing alcohol and sticker the pads on very good and boom brand new!!!! Thank you, I guess when it doesn’t stick to good it stops workingt for your protection otherwise u can get shocked or hurt, awesome!!!
Kieran Hendry
Level 1:
New Friend:
  • Posted on Oct 11, 2014
Kieran Hendry
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
36641
Points
Tried all this its still same lol
  • 1 more comment
  • Kieran Hendry
    New pads not working, they told me to change battery
  • DM Sammons
    -DMSammons
  • Donna Gendron
    Donna Gendron Mar 13, 2024
    My charger is not charging in the window where I see my battery it’s not moving with in the battery I have charged all night and still is only a small charge I plug In to belt and start bringing up frequency and it shuts off what do I do
Neil Whelan
Level 1:
  • Posted on Nov 20, 2020
Neil Whelan
Contributor
Level 1:
Answers
Questions
0
Helped
36641
Points
16
The left pad looked a little worn just in the middle, so I moved it slightly to the right, still got the flashing triangle and beeps. Took a battery out for 5 seconds, put it back in and all worked perfectly.
Kim Allen
Level 1:
New Friend:
  • Posted on Aug 03, 2016
Kim Allen
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
36641
Points
Hi I put new pads on properly.the triangle lights on and won't let me higher it up.thanks
  • Darrin Jan 08, 2018
    Take ace band and rap it around the belt on your waist then it will work you are not making contact
Fue Vue
Level 1:
New Friend:
  • Posted on Mar 16, 2015
Fue Vue
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
36641
Points
10
I WET THE PADS AND IT WORKED. It has to do with the fact that the pads aren't sticking well to the skin. I wet the pads on the black side that sticks to the skin. Works like a charm. No new pads yet
  • Kieran Hendry
    My pads are new and still same haha.
Tiago Al Lmite
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 23, 2015
Tiago Al Lmite
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
50335
Points
10
The cables that Connect the pins on the other side gets breaked, i Fix it, i replace the pins With bolts, now it work like a charm, see the all steps that i do...
https://drive.google.com/folder/d/0B6C5lV38JRuhUVdzNUdvVTZSWEk/edit
thumbs up please! !!
  • DM Sammons
    -DMSammons
RSL1
Level 1:
New Friend:
  • Posted on Jan 18, 2015
RSL1
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
36641
Points
By properly placing the new pads and removing the plastic protectors, the beeping was still going on while the triangle remains on the screen. However, upon wearing the belt, the beeping sound and triangle went away resulting the intensity levels to function properly.
  • 1 more comment
  • DM Sammons
    -DMSammons
  • Ronda McDonald
    Ronda McDonald Oct 14, 2017
    I tried it didn't solve the problem still beeping and triangle shape still on their
  • Paula Kavanagh
    Paula Kavanagh Apr 28, 2018
    I did not have alcohol so I put a little aloeVera gel and it
    worked great!
Anonymous
Level 1:
New Friend:
  • Posted on May 13, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
36641
Points
Hay my slender tone is beepin with a triangle in da middle flashin and on da lft side Dare is this ( - - flashin what wrong
  • Nadia Henzee
    Nadia Henzee Feb 22, 2019
    Please, whipe your skin with rubbing alcohol, make sure the pads are stick very good on you, attach controller and it will work, I just did this, I have 2 belts and both of them work so good now, best Wishes!
1 Related Answer
Anonymous
  • 1116 Answers
  • Posted on Jun 02, 2011
SOURCE: I just replaced the pads
Triangle error code denotes a pad contact problem.
These are the solutions for this error:
The triangle symbol has appeared on the LCD*
Pads not covering metal stud
Pads are worn
Pads on wrong way around
Liners still on the pads
Reposition pads
Contact your local distributor for new Slendertone pads
Ensure black surface of pad is facing you
Ensure liners are removed from both sides of the pads
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Slendertone keeps beeping
the beeping its becouse there is no contact between the pads and the skin (1), or the cables and the pads (2), or the cables and the controller (3).
what the manufacturer says:
try to change the pads by new ones
i did that, but still not working.
what i do:
i had the second problem, but i fix it, i cut the cloth in the back part of the pin (not in the front of the pin), and i discover that the cable that is attached to the pin was cut, i remove the the pin, then i replaced with a bolt, i attch the cable to the bolt and thats all.
i'm using it right now and its works great.
i answer on another post similar to this one, a put a link to my google account where you can see pictures of what i did.
thums up! thank you!
In a triangle DEF, sinD/sinE=7/10 and sinE/sinF=5/2. If the perimeter of the triangle is 16 ft., what are the values of the sides of the triangle?
I took a course in S.H.I.T. (special high intensity training) that declares the need to comunicate in English. Got a computer problem? Leave a message at the sound of a beep and a live person will respond shortly!
My slendertone wont turn on. it did and i turned it off!! and when i went to turn it back on it wouldnt turn back on and i have changed the baterys!!!
I've had the exact same problem! I turned it on, and the lights went on then I looked at the next step in the manual and thirty seconds later max when I looked at the belt it had turned off! And now it won't turn on again! I've changed tha batteries and it still won't work! Please let me know if you find a solution!
4helpful
Could you tell me how to turn off keypad tones when texting on a samsung Tocco
Adjust the volume of the key tones
In Idle mode, press [up /down] and adjust the key tone
volume.
Adjust the vibration intensity on the
touch screen
You can adjust the intensity of the vibration when you
tap the phone screen.
1. In Idle mode, press [up /down].
2. Select Vibration and adjust the intensity of the
vibration.
How do you work the Slendertone Belt? I lost the
hold it in front of you comfortably and pull outward (its pretty straight forward)
Vibration Intensity?
Most cell phones don't allow you to control the intensity of the vibration... you can only turn it on or off. However, if you get a rubber case for the phone that might help, because it will absorb some of the vibration.
Top Slendertone Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Slendertone Exercise and Fitnes Expert? Answer questions, earn points and help others
