PayPal Accounts Logo
Posted on Feb 18, 2011
I want paypal to change my e-mail address to read from [email protected] to the new e-mail address as follows: [email protected]
A
Anonymous
You will need to add the new e-mail address in your Paypal account under "Profile" and then "Add or Edit e-mail" After you do that, set the new address as your "primary" e-mail address. Your new e-mail address will now become your log-in name.
tip
I cannot access my Verizon mail _ Verizon.net server responded: Authentication...
Hi.
The following tip applies to users that want to access Verizon mail using an e-mail managing software as for example Outlook, Outlook Express, Eudora and similar.
The checkup procedure and server settings can also be used to setup your verizon email on a mobile or on a PDA.
If the Verizon server responded: Authentication failed, that means that either your ID, or your password had not been recognized.
Ensure that Caps Lock is not on.
ID and password are case sensitive, ensure that you use capitals only if needed.
Ensure that you entered the right user ID and password for your mail.
The ID must be your Verizon email address, or the first part of the Verizon email address (before @ sign). Password must be your Verizon email password.
If for example the address is [email protected] , then try first putting id [email protected] , if that does not work, try again with MyMail as ID.
The format that is supposed to work on Verizon is [email protected].
Ensure that the server settings you are using are correct:
1. Incoming mail server (POP3) - incoming.verizon.net.
2. Outgoing mail server (SMTP) - outgoing.verizon.net.
Ensure that you have not set the Log on using Secure Password Authentication (SPA)
Ensure that ports are POP3 PORT: 110. SMTP PORT: 25
Turn off any active firewall or security software. Also ensure that your router is not blocking port 110 (for POP server) or port 25 (for SMTP).
If all that does not work, then there may be an issue that depends on Verizon server. Also try calling Verizon online to find out if there is any additional issue that can affect your account.
Regards.
Check e-mail of paypal account
Sign in to PayPal using the old address then change it there. FixYa cannot change your info on another company's website.
How to change e-mail eddress
Once you login, on the my account page is a link that says profile. Move your mouse over that link and a dropdown will appear with the first option saying --Update email address.
CHANGED E-MAIL ADDRESS
Follow the following instructions-
1-Go to www.Paypal.com
2-Click on - Having Problem In Log in (just below username and password)
3-Now chose option 2nd(Forget E mail Address.)
Now follow them .
Changed e-mail address from [email protected] to [email protected]. Forgot what password is
go to www.paypal.com and click on "problem with login?" then follow the instructions.
2answers
I have changed my broadband and I am haveing trouble trying to change my email address .my new is [email protected]
What exactly do you want to do? Do you want to change the email address you are using for your Paypal account?
If you want to change the email address you are using for Paypal, you really don't have to change it at all. What you should do is to add another email address for Paypal. You can do this by, after logging in to Paypal, point your mouse to the Profile link, and then click on the Add/Edit Email link. Then click on the Add button to add a new email address. You can use this new email address in logging in to the same Paypal account you are using before.
2answers
How can i find my paypal password?
f you have forgotten your PayPal password, you will need to follow these steps to create a new one:
1. Visit the PayPal website at www.paypal.co.uk
2. Click 'Problem with login' under the 'Log In' button.
3. Choose 'I've forgotten my password' and enter the email address registered to the account.
4. Enter the security code by typing the letters and numbers shown then click 'Continue'.
5. Confirm account ownership by selecting and entering the information you want to verify and click 'Continue'.
6. Create a new password, which must be at least eight characters long and should not contain any spaces
I forgot my login name and password and need to change my email acct
You can easily retrieve your e-mail address and password.
#1. To retrieve your e-mail address simply go to. https://www.paypal.com/us/cgi-bin/webscr?cmd=_email-recovery and fill out the necessary information and you should get your e-mail that you will use to log into your paypal account.
#2. To get the password for this email, paypal will e-mail it to your e-mail address. Bear in mind that you must be able to read e-mails on the provided e-mail address that is also the address you used to register for paypal. You can simply go to https://www.paypal.com/us/cgi-bin/webscr?cmd=_forgot-password&from=PayPal
Top PayPal Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a PayPal Computer and Internet Expert? Answer questions, earn points and help others
