SOURCE: We have set up a
Check the log/details.
It will clarify if it is a server connect error or a log-in one.
It will give you the details as to where the function is falting.
It may be as simple as entering the file path correctly.
SOURCE: Canon Imagerunner 2020i scan to pc- set default send to address
you need to store that location in the address book, its under additional functions, once there you have to enter info for scan location
SOURCE: Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
SOURCE: HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
SOURCE: I have an IR5050 copier that is scanning to
use the Remote User Interface\\computer name\file name should get to destination as long as user name and pass word are ok
The following is the list of info required to setup smb scanning. The easiest way to enter it, is via the devices webpage. Make sure the folder is fully shared.
"Host Name" = The computers name
"Port Number" = Either 139 for windows XP computers or 445 for windows 7 computer
"Path" = name of folder where the scanned documents are sent/saved.
"Login User Name" = Windows user name
"Login Password" = Windows login Password
