Question about Akai LCT2060 Television
Hi! I have an Akai LC 26" 2660. Since a couple of days I have just sound and the screen stays black. When I turn it on, it lights up for a second and then is everything gone but the sound. Is not possible to see any picture at all, just the number of the chanel. Do you have any idea how I can fix this problem?
SOURCE:
SOURCE: Akai Plasma 42" PDP4294
sounds like time for a class action lawsuit.. mine went blank too.. and it seems like everyone with this model is having the same problem.. i wonder if akai has a solution i'll call them tomorrow.
Posted on Jun 04, 2007
  • 10 Answers
SOURCE: akai pdp4292 42in
FOLLOW THESE STEPS ON THE REMOTE 1-PRESS THE BRIGHTNESS KEY 2-PRESS THE FREEZE KEY 3-PRESS THE MENU KEY 4-PRESS ENTER . THIS WILL RESET ALL BACK TO FACTORY PRESET. I WENT 3 MONTHS WITH NO TV BEFORE I FOUND THIS OUT.
Posted on Sep 20, 2007
SOURCE: Screen powers up then goes blank after 2 seconds
Hi, was there a resolution to this? I am experiencing the same problem with LCT3285TA purchased at Radio Shack in Media, PA. Radio Shack has refused to service the unit and has put me over to Akai for the manufacturer's warranty. I'd like to know what to expect and if this problem with the Logo coming up and the unit shutting off/restarting can be easily fixed, thanks.
Posted on Jan 29, 2008
  • 4 Answers
SOURCE: power light blinks red - tv will not come on
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
Posted on Jul 24, 2008
  • 157 Answers
SOURCE: Akai LCT3285TA Television won't turn on
the problem is in the power supply(they know about it good luck fighting them)but there is good news.you can remove the power supply and replace electrolytic caps,EC18,EC19,EC20 all of them are 1000mf at16 volt use 1000mf at25 volt.you can also go to shopjimmy.com enter model number you will see power supply part number MLT169B
it will be cheaper for you to replace the caps,the board cost about $80.00 from them
Posted on Sep 24, 2009
Testimonial: "Dale Hunter's response was completely accurate. I replaced the three capacitors that he identified. And it has been working fine since 2009. Now I have the black screen problem. Help me Dale."
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
Picture but no sound on Akai 26 in flat screen
Did you fix this yet?Please let me know.Thank You very much!
Tyler
Feb 19, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
REAR PROJECTION TV NOT TURNING ON
I just got this tv free and it will stay on for 15-30 minutes and then turn off. Some times it will stay on all day, though, so its kind of weird. I have the 5499HD
Dec 29, 2007 | Akai PT5598HD 55" Rear Projection...
Akai 2660
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Dec 17, 2007 | Televison & Video
Our tv will not turn on
Our AKAI was just 14 months old. A few days ago, it died also. Blank screen, no sound, but the timer light will flash on a couple of times when you try to power it up. It even sounds like it wants to turn on. I paid a tech to come to my house $65 and it turns out to be the power supply $385. I checked other chat boards and many people are having this same problem with their AKAI 42" (PT4298HD) televsion. A real piece of junk this model! Sorry for the bad news!
Sep 10, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
No picture but has sound
leaky jungle IC. if your not enclined with this job. contact a certified technician on this matter.
May 04, 2007 | Akai LCT2660 26 in. HD-Ready LCD...
Akai LCT2060 Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
