The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items.
Please expain with words in fully spelled out to understand your problem
The neutral and drive shaft has come out of the tech drive or gearbox and is stuck in drive.Very hard to find a kirby place in vic to fix it.
yes was spot on but had fixed it already thank you.
