I'm trying to connect my headset to my Playstation3. I've inserted disk and connected USB to adapter. Disk does not read, or where do I go to make it read, so I can install wireless headset software?
Wireless bluetooth headset devices must be paired or registered with your system before use. to do this go to settings on the ps3 -> accessory settings -> manage bluetooth devices -> turn on your bluetooth device then click register new device
from there you may have to enter a pass key which comes in print with your device or if you bought the device used, you could use the default passkey of 0000
hope this helps. please rate me thanks and good luck.
If the headset is bluetooth then the ps3 should be able to connect with it while its in pairing mode form the settings menu. if the headset will not function without other software then the ps3 cannot use them. the ps3 will only read the select music, video, and game discs.
SOURCE: pairing the insignia bluetooth wireless headset with an ipod
Perhaps either its pairing log is full, thay hold a number of pairing internally, and may need to be cleared to make room for another....or the headset may need to be reset, either way...heres the scoop....to clear the pairings hold the track forward/track backward buttons down together until the light flashes Purple....Empty pairing log......
If not then try pluging in the set to the charger and holing the 2 volume buttons down the same way..this will shut it off and reset it if it went a bit screwy on ya.... Merry Christmas
SOURCE: Lost my Insignia Bluetooth Headset Disk
http://insigniaproducts.com/products/portable-audio/NS-BTHDST.html
SOURCE: Insignia NS-BTHDP ok with phone, pairs with PC but can't connect
Make sure the headphones are set as "default" under Control Panel>Hardware and Sound>Sound>Manage Audio Devices - same for microphone if you're using it for online speech.
Where is the mircophone? I was told that this was all I needed.
