I have a Magnavox 51" Projector TV. Model 51MP392H/17.The TV does not
turn on when I hit the power button. The only thing that does happen is that
when I do hit the power button, the button itself turns a solid red for a few
seconds then it flashed red for another few seconds then it goes off. Any take
on this? Thank you
Well I forgot to mention that when I do turn on the TV the button flashes 9 times then pauses for a second and repeats the flash 9 times over again.
Is this a error code for the 51MP392H/17 ?
Thank you
Joe
Hello bullmuscle,
This is a power supply problem, I would suspect the HV power supply because the primary and secondary supplies anymore are tied to the HV power supply. This type of repair requires certain pieces of equipment, to test voltages, look at signals, and to if need be test for shorts in inductors (Switching PS transformer and Flyback transformer). I would not recommend that you try to fix this yourself, The cost for this type of problem is not that expensive and can be done in one evening, if the parts are available. You may be fortunate and it could be just a blown fuse, in the HV or LV power supply circuit
I hope this helps,
Thank you,
Shuttle83
