Question about Just Wireless Bluetooth Headset Wireless Headset
Brand new Just Blue Wireless Bluetooth BK-15 has been on the charger for 24 hours now, and won't hold a charge. It works fine on the charger, and able to pair with phone. But once it's disconnected from the charger, I get nothing. This is the THIRD one we've had now, taken 2 back thinking it was just faulty! Help!
    Top Expert:
  • Just Wireless Master
  • 53,745 Answers
Take it back and get your money back the go somewhere else and get a get a better quality unit
Posted on Dec 09, 2017
4 Suggested Answers
SOURCE:
SOURCE: how can i pair the just wireless bluetooth headset with my phone
with the headset off, press & hold the power button for about 9 seconds until the indicator light alternately blinks red and blue. Set your phone to search for a new headset or bluetooth device. When it finds the headset, the passcode shoudl be 0000
Posted on Jun 04, 2009
  • 277 Answers
SOURCE: hi my name is darrell
ou need to sink firs hold the buttin in till it flashis gren and red the go to the phone search bluetooth device it will then go green and should be connect
Posted on Jan 06, 2011
SOURCE: my bluetooth will not work, ive been charging it
it wont charge its garbage im taking mine back tomorrow
Posted on Feb 01, 2011
Zagg keyboard doesnt work
Mine went dead after about 3 weeks. Once I realized there was a charging port which is not IPhone, but droid type. Began charging. Would not recognize until I went to blue tooth setting and said forget device. Then turn bluetooth on and then hold bluetooth key down on for 3 seconds or so on keyboard. Then it worked. I guess dont let it run till it dies.
Apr 16, 2013 | ZAGG New Apple Ipad 2/ Brand New Ipad...
When I plug the headset into the charger it blinks red and blue and won't hold a charge. Is there anything I can do to fix this?
You might have to check the adapter for charging voltage , if faulty you will need to check the wires, the adapter, if faulty replace.
If the adapter is fine and giving the right voltage then the battery within the unit is fault. you will need to open and check to confirm and replace.
Oct 09, 2010 | Insignia Bluetooth Wireless Headphones...
Motorola H500 bluetooth won't turn on!
Hold the phone button down for about 4 seconds.. The light should blink 2 times and then stay on to add device to your phone once connected light will go out...Hold button down again light will blink 3 times and go off...........
Aug 07, 2009 | Motorola Mobility H500 Wireless Headset
Old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
Aug 05, 2009 | Motorola Mobility H550 - Bluetooth Headset...
Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Jun 19, 2009 | Insignia Bluetooth Wireless Headphones...
How to reset a bluetooth
If you're resetting it one you're phone just delete the device in your bluetooth setting and set it up again. If trying to reset the bluetooth headset, hold the power button until the blue light stays on. That should do the trick.
Mar 16, 2009 | Motorola Mobility H350 Wireless Headset
Bluetooth wont turnon new unit out of box
Pardon me if you have already tried this but with my em236c I had to hold the Answer/End button for about 15 sec before it flashed red/blue. The manual doesn't say how long to hold it. It took a couple of tries for me. Hope this helps.
Jan 05, 2009 | Southern Telecom Emerson Bluetooth Headset...
HOW TO INSTALL A MOTOROLA H550 BLUETOOTH HEADSET
Usually to pair a new device like that, there would be some trick to set it up. Im not familiar with your exact model, however ive had success with holding some buttons in.
Usually you would hold down the power button, or perhaps the volume up and down together, hold them down for a few secs and the light will go blue/red/blue/red to show its in pairing mode.
Jun 18, 2008 | Motorola Mobility H550 - Bluetooth Headset...
Samsung wep 150
I think i know why your bluetooth goes red then green. It is because your using a wrong charger like different make of the the charger or is it you never use it for a long time so is completely dead and you have to buy a new charger or bluetooth.
Nov 12, 2007 | Samsung WEP-150 Wireless Headset
Won't charge!
HEADPHONES AND SPEAKERS Hi There Try this, VOLUME Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. WIRELESS\BLUETOOTH Check your battery if it is drained. Try replacing them witha new one or charge them if they are rechargables. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester. Hope This helps =============================================== If you are having trouble with a Newly bought items then return them a demand a replacement or a refund!You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Motorola Mobility H500 Wireless Headset
Just Wireless Bluetooth Headset Wireless Headset Logo
101 people viewed this question
Top Just Wireless Radio Communications Experts
Marvin
Marvin
robert
Don Eagan
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
