Hello Rowjck, I'm going to share few steps, just follow them. It help you to fix it.
Right click on the desktop -->> Clicks on Properties -->> "Settings" tab -->> "Advanced" button -->> "ATI Displays" tab Then press M or click on the word monitor (in bold above the image) At the bottom of the "Monitor Properties" window that just popped up, select 1366 x 768 in the maximum resolution drop down list. Now return to the Display Properties > Settings tab and select it there.
I hope these steps will help you, if you still face same issue, hit me on +1 (844) 355-5111 (toll-free).
Cheers
John
SOURCE: how to change the resolution of Acer AL1702Wb 17
On windows XP and earlier :
1. Right Click the desktop
2. Click properties
3. go to settings
4. the resolution slider is there. Try different resolutions untill it looks good.
SOURCE: acer x191w monitor background is moved to the right with about 2inches of black on left side.
I tried this and it still does not fix my problem. I went into Menu and hit reset by mistake and that totally screwed up my monitor. Now the left side gets cutoff and no matter what I change the resolution to it does not fix it.
Whjat should I do?
SOURCE: Acer x223W Monitor issue - not displaying correctly in native resolution
hi, when all connected press and hold the FN key on the bottom left of the keypad while pressing one of the function keys F1 to F12(the one with picture of a screen or monitor). You may need to press it more than once but if will eventually switch the display over to the tv
Hope this help
SOURCE: Screen resolution for Acer P221W
1680x1050.
It also depends on the video card how high the resolution can go.
That's the max resolution though.
Here's the complete specs for your monitor.
Have a good day!
