Open up the call app and then go to your favorites. There should be an "edit" button on the top left. Press that and then there and soon three little metal bars show ,choice next to every favorite contact. Now drag those bars down or up any which way you like to organize the list.
Hope this helps
SOURCE: cannot delete call logs in
I have tried to delete my call log from my phone however I get an "invalid selection" error message. The logs do not have any time and date next to the names and I am unable to delete.
SOURCE: My Nokia C3-01 keeps freezing, can't log in to get
This solution should help fix the issue. I advise you use the Nokia PC
Suite to backup your phone data prior to doing this reset. Also, you
should download and install Nokia Software Updater and use this to update your phones firmware and software in the future.
Remember to backup your phone before performing these functions.
SOURCE: I cannot clear my log
try these steps below.
To hard reset your Nokia C3 you just have to press
*#7370# and press Dial. The phone will request the security code that
is by default 12345. Please be aware that you will loose all the data
in your phone, so you should backup all relevant information.
If you want to soft reset your Nokia C3
you need to press *#7780# and then Dial. The security code is 12345.
Once you complete this, your phone will come back to factory settings,
but you will not loose personal data. Anyway it is recommended to make
a backup before performing any of the mentioned procedures.
SOURCE: my nokia c3-00 mobile is
You can get the restriction code here mobileunlocksolutions.com to your mobile Nokia C3...You need to specify the network provider or else contact the service...
